At first glance, how easy would it be to repair the front end of this r34. Mechanically it is fine and rad support is in tact. Would it be as simple as buying a new bonnet, bumper and fender or will it take more than that.
When you say "intact", do you mean "it's there and it's bent", or "it's not damaged at all"?
Because if it is not damaged at all then you repair does start to sound like what you want it to be. You may still have to straighten some stuff up to get guards and bumper to line up, because there is obvious damage on the LH front corner.
But if the rad support is bent, then obviously it will need to be straightened, and if it is bent then the front end of the chassis rails might not be straight either. In which case your repair is going to take some proper chassis work.
 Share
