Recently my R32-GTR started running really rough at all rpms, so i did a compression test.
the results:
Cylinder 1: 165
Cylinder 2: 165
Cylinder 3: 130 => 165 when doing a wet test.
Cylinder 4: 155
Cylinder 5: 165
Cylinder 6: 175
Cylinder 3 with 130 concerns me, do i need a rebuild? should i check for other reasons my engine is running bad? and what could cause this (suspect its the infamous ringland) i also have pressure in the sump, but no smoke from the exhaust.
extra: i have changed, injectors, plugs, coil, ignition module and wiring loom so far.
Thanks for all replies! :)
-NorGodzilla
https://www.sau.com.au/forums/topic/480764-bad-compression-on-one-cylinder/
Given the evidence of a significantly different cylinder health, of course it could be to blame.
However, just about everything else on the car could be responsible. AFM, CAS, wiring and connectors for each, coil loom, dirty/dud injector and/or the injector loom. Low fuel pressure from failing pump, boost rag, blocked cat, burnt valve, chipped cam lobe, timing out, valve timing jumped a tooth.....do you want me to go on?
I get that there is alot that can cause this. i have checked the cas, maf's, injector filters, fuel pressure, i dont have a cat, i have a new coil loom, timing, and that the timing belt has not jumped a tooth. still i understand that there is a hundred more things that can cause this. anyhow thanks for the input.
46 minutes ago, tridentt150v said:
The difference between a dry and wet test says bore issues, rings, lands, gudgeon out etc to me.
Oh yeah, but while the compression was a bit low, it probably isn't low enough to cause rough running on its own. I mean, it might, but it's just as likely to not. Hence why I gave the laundry list. Many other things more likely to cause rough running than a cylinder down 15% or so.
  • Like 2
Very true, I wasn't really thinking of the rough running issue when I replied.   I guess he went hunting rabbits and looks like he might have shot a squirrel :)
  • Haha 1
On 13/07/2020 at 4:36 AM, tridentt150v said:
The difference between a dry and wet test says bore issues, rings, lands, gudgeon out etc to me.  Can you get a bore scope and have a look, you might see marks on the wall?
i have now taken a look with a camera on the cylinder walls, it seems like there is a decent amount of scratches in all cylinders, i suspect this is just normal wear, due to the engine being almost 30 years old. in cylinder 3 there seems to be one scratch that is alot deeper than the others, this one seems to be quiet deep into the cylinder wall. i understand that this can explain the pressure in the sump and blowing out the dip stick. do you guys think i should continue searching for other issues that may cause the engine running rough, or should i pull the engine now, any suggestions on what to do?
Well, look, the engine is f**ked right now. You should rebuild it just in case that scratch is the warning that something is about to break away/seize the piston/wreck a valve/turbo/etc.
If you do that, then whatever the very likely other cause of the rough running will still be there when you try to start up the freshy and run it in, which won't be good.
So fix both.
  • Like 2
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
