Hey man just be clear you are looking for the clear weather strip that are about an inch wide that go over the driver and passenger window?
if so I have only a drivers side one if you need.
can send a pic
can send a pic
Not sure how easy it is to see, but attached picture is what I'm after. The strip that goes around the doors.
I think you are talking about the weather strip retainer correct ? If so these are worth mega bucks for the 32 new, like over $1000 per side. RHD have them, but Kudos has them in stock for $660, which has been reduced heaps as they obviously can't move them.
http://www.kudosmotorsports.com/catalog/upper-window-weatherstrip-retainer-suit-nissan-skyline-gts25-door-coupe-p-1840.html
Here they are on RHD
https://www.rhdjapan.com/nissan-oem-weatherstrip-retainer-left-r32-2dr.html
Do you want to replace them because the covering is all cracked ? If so don't replace them. Strip all of that coating off and polish it. They are stainless steel underneath and looks actually better than having the coating on. Did this on my 32R.
Yes, those are the ones.
Ahh they weren't on the Kudos site the last time I looked. Yeh they do go for mega bucks.
Ahhh didn't realise it was just a coating. Yes mine has got some bad cracks on it, it also had a weather shield on it which I've taken off and didn't help the situation. I'll have a go at stripping it all back. Thanks BK.
If anyone wants to let an old set go for a couple of hundred per side, I'd still be keen.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
