Hey people, I've had my black 1997 R33 gtst now for 11 years, since it was imported from n. Its completely stock, in what I'd assume is really good condition apart from needing a good vacuum; and it's completely stock (apart from 34 GTR rims). Has a sunroof, 186,000 ks but runs like a dream
Time to sell and get a more practical boat. Anyone know what they're worth these days? I bought it in 2010 for $14k. I'm going to cry when I sell it, honestly. But I can't garage it ?
Appreciate any guesses etc.
https://www.sau.com.au/forums/topic/480866-r33-gtst-s2-values/
6 hours ago, Duncan said:
It's worth about $40k if you can get it to the US....
I'll probably just go the local private sell tbh, it's just hard to tell what it could be worth seeing as values were down a while back and I was thinking I'd be lucky to get 10, but nowadays they're going for more. Also, pretty much never stock to its hard to gauge. Even if $40k sounds pretty damn good!
