So, a friend called me to see a GTR with a built RB26 that has been smoking hard under WOT load , it made 480hp, 360tq with the last turbo (precision). on the dyno and they saw smoke coming out of the exhaust housing and then the exhaust pipe.
Before that, they thought the turbos were the problem. new turbos, same thing, precision single turbo, same thing.
So i went to help, checked compression (all good around @ 170psi), did a leak down, found cyl 1 and 4 giving a loss of around 10-12 psi @ 74psi down to 60 and 70psi to 54, other cyls had 2-4psi loss. This is my only clue.
* Checked PCV valve, its fine, plugged it just in case
* Took valve cover hoses off (oil catch can has no crank return nor atmosphere vent, its basically a closed box)
* Oil return seems adecuate, no rough path to the crank
Then, we tested the car, hard wot 1st,2nd and 3rd gear, it only smoked on 3rd gear WOT at high rpms (6500+) and it was a lot of smoke, it blocked the lane behind us. Oil came out of the disconnected valve cover outlets and fell on the turbo and block. As expected. we have to retest with the hoses pointing to the intake side but since they DID see smoke coming out of the tailpipe on the dyno, i can only hope that the PCV being completely closed off could have done something internally with its built pressure on the dyno and burnt oil inside the combustion chamber. I saw some wetness on the pistons from the plug hole, saw no oil or sign of it on the downpipe and exhaust housing.
But being realistic... i fear that something is wrong either on the pistons or valve train area. I thought it was the PCV system because i saw the closed box and wondered about the PCV valve etc.But seeing the compression fine but a bad sign on the leakdown. So this left me curious.
I thought a cracked piston ringland or a bent valve or bad valve seats would show at all RPM ranges, to different degrees, but this engine only did its smoke screen on 3rd gear, WOT, after 6500 rpms. Any ideas? experiences? i cant open this engine for fun as its not mine so im left with the sad state of not knowing for sure.
Edited by Lopin18
https://www.sau.com.au/forums/topic/481013-rb26-smoke-during-3rd-gear-wot-only/
Both hoses from the valve cover go to the oil catch can, PCV valve is joined with one of those valve cover outlets.
The catch can itself has 2 inputs from the valve cover outlets. NO outputs on the catch can, meaning no return to the crankcase, no vented filter, no outlet to the compressor pipping.
So basically pressure just builds up, theres nothing venting or allowing the crankcase pressure to go anywhere (just the PCV valve, which will be closed during boost)
Well that is completely f**ked.
Neat, i was thinking so much i didnt remember that the oil return line from the turbo is another path for pressure to build up. Thanks for the feedback. On monday they will trst the car again to confirm, ill reply back then
in the dyno they noticed the valve covers leaking pressurised air, along with oil, but the valve covers were a bit loose, i can imagine the pressure buildup was enough to cause what they saw...
I don't really understand how such a simple thing can be so misunderstood!
Either block your PCV and vent the rocker covers to atmosphere into a CATCH CAN - with a hole at least 1" in diameter for each hose going into it so pressure can escape, preferably with a filter/s to catch some of the oil jizz
Or keep your PCV valve stock and install a SEALED OIL/AIR SEPARATOR r that goes between the rocker covers and hose into the turbo inlet
They are the only two options that exist for it to work properly
  • Like 1
:D U would be surprised how many people dont take crankcase ventilation into account.
They tested the car today, no more smoke. So hopefully its just working the crankcase ventilation.
Thank you btw, i had missed some concepts including the turbo oil return line.
    • Robertson was a Canadian inventor, and it absolutely reigns supreme here. 95% of our screws are Roberston. It's literally the only option you can buy off store shelves. What would it have lost out too? I believe it's also very popular in the US.  My reference to imperial was pointed to both NPT and BSP.
    • No. BSP lost to the cultural/technical imperialism of living next to Trumpistan. Face it, Robertson screws were better and still pretty much lost out to the yank stuff. The Europeans hate the Brits and they don't use NPT. NPT is just as "imperial" as BSP is, being based on those useless inch thingos. Just done differently.
    • I live in Quebec. Our license plate slogan is "Je me souviens" Translated is "We will remember" as a reminder to when England conquered us and that we must never forget what they did. Long story short, BSP is unheard of here due to being an English design. I'm surprised our nazi anti english government office the OQLF hasn't kicked in my door yet just talking about it, yet alone imperial anything.
    • Thanks for that! I did a quick Google search looked up some of hydaulic stores and didn't see it listed on the website, I'll give them a ring. Also found out later that I can buy 2 oem bleeder bolts for 10 bux and come with the washer which I might do so I don't waste the money it costs in petrol to find 2 washers (already did that lol). The old copper washes look in good nick, I drove it after taking it off and putting it back on and didn't see any  Part number here for reference if anyone needs: 14053-42L0A
