Good morning everybody. I’ve searched on this and can’t find anything on my specific problem. So I’m having a slight “annoyance” with my drivers door lock. The driver door will not lock/unlock by the switch (but the passenger door works just fine). Manually locking the door via the key or inside the car will lock the door (and the passenger side door). Now, the really annoying part is from the time I start the car to the time I shut it down, every 3 or 4 seconds the driver door lock attempts to actuate. This doesn’t always happen, but happens enough to drive me crazy when driving with the windows up. I should add that the speed sensitive auto locks have never worked. I was thinking of snipping the green wire at the brain to disable the feature altogether, hoping this would remedy my problem, but I wanted to find some more information before I decided to do that. Any thoughts? Car is a 95 GTS25T S1 without keyless entry or any type of alarm. Thanks!
Hmmmmm . . . . check the drivers side door window control unit.
Some one may have replaced it with a later model one out of a series 2 and fiddled with the electrical wiring to get it to work.
From memory a Series 1 has a 9 pin plug and a Series 2 a 11 pin plug . . . or was it vice versa ? ? ( oh my Oldtimers disease is at maximum at the moment ! )
I'm sure some one on here can confirm that.
Thats actually the Power window amplifier part number 28515-15U00 the small smd relays fail inside. Very common. All three  of my family S1 R33's have failed with various problems but same unit. New they are $270 plus freight.
Edited by Rusty Nuts
spelling
So could that have something to do with a very “loose” driver window switch? You even look at the switch and the window goes down. Also, the driver window works most of the time, but when I’m putting up both windows at the same time, the driver door sometimes waits a few seconds before working
Also, what is the purpose of this amplifier, exactly?
Edited by LiteraCola
"Loose drivers switch" part of the button has broken away on the inside button itself.
This holds a small white plastic spring loaded pin.
Pop the button of carefully, after taking the unit out, and look for the broken plastic bits, clean out the lubrication grease with ethanol and super glue ( I believe it called crazy glue in the US ) back together.
Bit of a fiddly job and you may have to put a small piece of supporting plastic in to stop it breaking off again . . . . or you can buy a whole new unit for a gozillion dollars !
The signal itself from the switch is low voltage/current not sure which. the signal operates the relays in the amplifier which switches the main supply to the door locks and window motors
Alright, so during my door speaker swap, I decided to try and tinker with this loose window switch. I removed the switch panel, popped off the window switch and a small piece of plastic fell out. I cleaned up all the grease with brake cleaner (on a cotton swab) and used some of the DevCon Plastic Welder stuff I “borrowed” from work a hundred years ago. I let it dry over night and tried to slide the pin back in. It was pretty tight so I tried to sand down some of the glue. That didn’t work, so I sanded the plastic pin just a smidge. Lubed it up and slid it in (giggity). All is well; my switch isn’t loose anymore, and I don’t hear the constant “clunk clunk” inside the door while driving. Two birds with one stone?
My drivers door lock switch still doesn’t work, but that’ll move down the priority list since there’s a nifty manual lock bottom less than a foot away ??‍♂️
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
