Hi Guys,
Im trying to get my head around whats involved to do a manual gtt conversion to an auto hr34 coupe. I'm just wondering if anybody here has done this before, what all the differences between them are(stuff im going to need)?
So far on my list ive got : Engine, box, diff, driveshaft and brakes.... basically the whole f*cking car ?‍♂️ I've also read here that it uses different shocks.... don't tell me it uses different sub frames too? If i was to go down the road of a doner car, would a mt/turbo stagea be a straight bolt on, bolt off situation?
 Any help, idea's, feedback, criticism all welcome. Just trying to get my head around it. If the answer is buy a smashed gtt sedan or stagea, and transfer everything over, easy. If the subframes are different, but i can get away with running different coil overs? Thats great too, i'l just buy a 33 box, neo and all the other stuff separately.
(Before you tell me to buy a GTT, im located in Japan... and the average price for them is now 2 million yen. I was a able to snag a mint, own owner gt coupe for 600k & parts/doner cars here are cheap)
Edited by Nippon_nick
You don't need to worry about the suspension. GTT have fork type rear dampers. Your car has eyelet type. But that's the same as R33 GTST, so not problem, there is suspension available.
Your rear subframe won't have HICAS. Win. That's one less thing to worry about.
Your car won't have traction control. So if/when you put a factory Neo RB25DET ECU into the car, it will chuck the shits at you because not TCS computer and probably no ABS computer eithers. You will need Nistune to dial that out, or an aftermarket ECU.
You will need the engine bay loom, and the driver's side engine bay/gearbox loom, and you will probably still have to do wiring mods.
You will need a clutch pedal bracket and pedal, master, wiring for the clutch switch, etc.
Buy a VQ37 and CD009 instead.
Ok, cheers mate. This is exactly the info i needed. The suspension is a relief, sounds like it should all be straight forward except for the wiring. I take it GTT sway bars just bolt in too? Id love to go something like a VQ but that's starting to sound a bit too ambitious for me. That said I'm still dreaming at the moment and gathering info. Still months away from starting this so maybe i grow a pair of balls in that time. Thanks again.
Ok. I was really hoping i could get away with just swaping ecu's and using the original wiring. If i really need all the wiring too i should really just buy a doner car, will be far cheaper and easier i think. Manual turbo stags here are dirt cheap.. will that work? How about a 4wd one or is that too much work?
The only thing that will directly bolt on is the car you are trying to turn this in to. Also it won't directly bolt on.
Your ABS will be different to a GTT, so your rear diff is a S15 style too. Which you will need, cause you will have an open diff. The closest you will get is the looms etc from a GTT, but be aware, this will not plug and play and "just work" you will have cluster issues (speedo etc) to deal with.
This car will teach you many things, in $ or in learning. There is no completely non-thinking way to achieve this goal.
2 million yen is what they sell for here too. You will only save money in sweat equity.
Source, had R34 Non turbo, then put a turbo motor in it, then obtained a GTT, then manual converted it, then put a LS V8 and T56 into that GTT. I've seen things.
You will too.
You will too.
Thanks mate. So it sounds like again, the biggest problem is going to be wiring. Il give your build thread a good read.
It's not actually so bad - If you have a manual gearbox from a R33 GTST this is something that has been done many, many times. See also: a R34 GTT gearbox. Just make sure it's a turbo gearbox.
The workshop manuals will get you home with a gearbox conversion and/or its been covered here many times.
This fixes 90% of the problems, because the only 'hard' stuff is making the auto work. If you have no auto to talk to anymore, then eh, any of the WIDELY available ECU's can run the motor, and the your brain can be the ECU for the manual :)
  • Like 1
I can go with anything really, whatever is easiest /cheapest.  The cost of these cars is currently out of control here BUT parts are still somewhat cheap thank god. I will keep my eye out for a binned manual gtt sedan / stagea over the coming months. That way i can get EVERYTHING. If i cant do that i will just get a 33 box and neo from the wreckers and go that route.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
