So i have been doing a build putting a rb25det from my written off r33gtst into my e36 BMW. It all starts and runs well apart from stalling when i give it a rev over 2000rpm. The motor is mostly stock. Aftermarket turbo, FFP and that is about it running stock ecu. The AAC has be cleaned idle set to 900rpm, im just abit lost on what would cause this to happen as there was no issues when it was in my 33, i hoped someone could give me some ideas to what could be causing this.
Thanks.
https://www.sau.com.au/forums/topic/481885-rb25det-keeps-stalling/
You should be getting between 35to maybe 40 pounds of pressure on the fuel rail, and as for voltage any sensor that's going to tell the engine to shut down make sure it has adequate voltage ie coils injectors knock sensors things of the such
1. Check fuel pressure at the rail is 43-45 psi without vacuum connected on reg(block the hose off so no vac leak)
2. AFM is clean & plugged in and is around the same distance as factory away from turbo.|
3. Coils are getting 12V and grounded correctly.
4. Alternator is generating greater than 12.8V at idle
5. Fuel pump is wired and gets 12v & a good ground
Will most likely be one of these but also depends on how the loom has been wired into the bmw
thanks, i still need some parts to set up the fuel reg but will check asap. thanks for the psi stats.
will go though and check all the volts on all those parts.  I am confident that they are getting what they need, but will go over it over the next week. I am leaning towards the AFM problems so i am trying to get one i know works ans see if that changes anything. will update once i have done that.
thanks again for the info and ideas every one.
  • 1 month later...
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
    • Hi, I need same this wing nismo , Does anyone have one for sale?  if any one have can contact me  00966546888343
    • Nah, lots of insurance repairs on V36 and V37 for pedestrians deployments. Reasons ranging from possums, to extremely severe potholes have deployed them. However, paying for the full repair can still be upto $5k AU some people have noted!
    • Hi, i got 1998 r34 4 door auto abs model and its manual converted with bigbox when i bought it . I successfully find the neutral and reverse light wire but can’t find the speed signal wires for speedo drive. I know its grey plug but on my loom no grey plug with 2 wires . I opened the loom upto where it getting branch with other wire, i’m amazed they is no wire. So need help how to fix the speedometer problem. I search on google it says some r34 model measure speed from diff sensor. Is it right? I talk to a wrecker he say no this isn’t right, i’m kinda stuck. Please help
