I have for sale a new Idler bearing to suit an rb20 or rb25 engine. U need to replace one of these when you do the 100,000km major service on your engine.
I bought this for my rb30det project, but ended up using two tensioner bearings instead.
One of these from a Nissan dealer is $272 - RRP for ONE ONLY!!!
I will sell this one for $120 -includes postage anywhere in AUS. :D SOLD
Also for sale is a two pairs (front, and rear) of lowered springs to suit a r32 gtst. Lower than std, but not enough to attact attention from police :mad: I removed these, only because i replaced them with a matched set of bilstein suspension.
Offers over $150 in Adelaide, or $150 anywhere else in Aus. SALE PENDING
do you have a pic of your car wit hthe springs in?
i'm interested but don't want it too low (one person's opinion on 'its not too low' and another person's opinion can be totally different...)
Nah unfortunatly i dont. The Bilsteins i got in there now sit above the top of the tyres by 30 mm...these would sit a little higher again.
Not overly low....but not std height. They are still on the std springs atm, so lemme know if you want em. I can measure em if you want....
hmmm considering still... will get back to you
how old are the springs? what brand are they?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
