Gidday
Im having a nightmare of a time with my r32 headlights. I bought the car as a half finished project(original ca18, manual. Now rb20det, full 5 stud subframe setup)
All lights work, except headlight low and high. High will work via the flash switch.
I have researched and found common faults with the headlight rotary switch. I have stripped the switch, cleaned up all contacts, and confirm power in, and then switched power out of this switch.
My problem now is between the switch and the lights I am losing that feed. I have searched alot for a wiring diagram to try and trace the wiring without having to remove the dash but cannot find one at all!
I had contemplated running new low beam wires from switch to lights, but then I will still have high beam issues.
Any help on this would be greatly appreciated.
Cheers
https://www.sau.com.au/forums/topic/482092-r32-headlight-issues/
12 hours ago, joshuaho96 said:
https://www.facebook.com/groups/gtrusa/permalink/514218625447824
The Australian R32 GT-R service manual is out there.
Thanks Joshua. Greatly appreciated.
Will have a hunt through this, hopefully the gtr and gts light wiring is similar enough
On 13/03/2021 at 11:57 AM, joshuaho96 said:
I would imagine it's identical, especially for the reflector lights.
Perfect! Found the issue between headlight switch and indicator stalk. Dont know exactly where the break is but just cut and rejoin with new wire between the 2.
Thanks alot for the manual, makes it alot easier to know for sure what should be going where.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
