Hey guys,
I hope you are all doing well. Seeking your wisdom on something that has me puzzled.
The OEM brake booster on my GTR was bad. So I decided why not clean up the bay and get something new in there in place of it. I replaced it with a  Wilwood Brake Booster Delete Kit (PN 260-10375) - I looked up the stock specs on a r32 GTR (non SpecV) and found that it is a 25.4 mm (1 ") bore size. I sourced a STAINLESS STEEL 4 WAY BRAKE UNION and STAINLESS STEEL 4 WAY BRAKE UNION to put it all together. There we some fittings that were needed as well but overall it is installed and front and rear have been bled.
No matter how many times I bleed it and make sure there is no air in the system. The brake pedal is soft, if I pump the brakes it'll get firm but then go soft again. Definitely not able to drive around at all at regular speeds. The guy at the shop that installed it and has my car (I been really busy with school and work and decided to have someone take a go at it) cant get it to work.
He suggest to find the stock brake booster new or have my old one rebuilt. At this point I agree. I don't know what else it could be. You all have any info or insight?
Pending your advice and help.
https://www.sau.com.au/forums/topic/482859-1991-r32-gtr-brake-booster/
I don't see how an issue with a variable pedal could possibly be due to not having a brake booster.
Basically the booster adds assistance to make the pedal lighter (when the engine is running and making vacuum). Without a booster it should either be just right, too hard or too soft at all times depending on the master cylinder bore size and where the pivot is on the brake pedal (pedal ratio)
What you are describing sounds like there is still air in the system somewhere; when you first press the pedal the air compresses which is why the pedal is soft and on subsequent presses because the air is already compressed you get the proper hard pedal feel as the wheel cylinders move.  Do you have a pic of the changes you made around the master cylinder (or elsewhere like abs?) and how are you doing the bleeding?
  • Thanks 1
Duncan,
Here are a few pictures of the current changes and set up. I never had an ABS module on it when I got it.
Let me know if this helps.
Break down (hope it's not too confusing)
They are color coded to the description.
Edited by Jjtxaz24
I think that does help; there is a high point in the "to 4 way" line which is above the master cylinder fluid level; it is possible you have air trapped there no matter how well you bleed it.  Can you re-bend/re-route so that no brake line is higher than the master cylinder fluid level?
Also, how are you bleeding; manual with a person pumping a pedal and another opening a bleeder into a (hopefully clear) hose, or vacuum bleeding at each nipple, or pressure bleeding from the master cylinder.  At least having no ABS removes that issue as you can get air trapped there too because valves cycle when the ABS actuates.
  • Thanks 1
Dam that is a good catch. I wasn't sure if that mattered or not but I feel that you are right. I can see if I can rework it. The guy at the shop built the lines and that's how he set em up i just gave him a diagram of how everything should be routed.
He said he would bleed the brakes manual. So I'm assuming 2 people. One pumps the brakes and holds pedal down, the other cracks the line, fluid pushes out then bleeder is closed. Rinse and repeat.
Yep, so the reason I asked that is vacuum and pressure bleed can be more reliable, manual bleed you can make errors (eg allowing pedal to retract before bleeder is closed, or not using hose to ensure only fluid gets pulled back in, or simply not flushing enough fluid through to clear out all bubbles because it is such a painful process......)
  • Thanks 1
Maybe I can try and vacuum/pressure bleed them before I redo the line to make sure there is no. I ordered a brake line kit to rework that main line so it is lower than the master cylinder fluid but it wont be here till next week. I wasn't able to source one locally.
The front Brembo's have speed bleeders on them so theoretically it should allow air out and not let anything back in. I will rebleed the system and when the kit shows up I will redo that line. **fingers crossed** hopefully it works.
Good news is I was able to bleed the system, used a vacuum bleeder and took about 10-12 minutes on both rear calipers,  There was lots of air. Fronts were good to go. I had speed bleeders on the brembos so took like 3 pumps and they were good.
Current new issue is my stock and aftermarket boost gauges aren't reading anything. They stay at 0 at all times.
  • Like 1
Are they pinned at the minimum level or are you saying they read atmospheric? If it's the first then I would trace the power and ground. If it's the latter make sure the vacuum line is hooked up properly.
  • Thanks 1
Gauges just read 0/neutral spot where they land if the car is off. They don't move at all. I found a torn vacuum line leading to my aftermarket greddy analog gauge. And just replaced it ziptied and made sure all lines were tight and good to go. Still nothing.
This one stays at 0
this one goes to zero when I start it.
Here's the stock boost sensor and an aftermarket one. The aftermarket one isn't hooked up so I'm not worried about that. The blue line goes to the balance tube where the boost signal is grabbed from.
Edited by Jjtxaz24
I removed all the vacuum lines (to the stock and aftermarket boost gauge) and left the one from the back of the balance tube (blue line) and plugged that in directly to the stock sensor. Nothing. Stock gauge stayed in the middle. I unplugged the pig tail from the stock sensor and in doing so it let the stock gauge turn off as if the car was off and the needle dropped. So there is a signal going to it.
It has been sitting for a little while, and before it went down I was able to get a signal/read out on both gauges. Issue was I forgot to plug in the vacuum line in back of the balance tube and couldn't figure out why i was hitting a wall (oversight on my end.)
On 10/4/2021 at 4:31 PM, Duncan said:
Not plugging it in ......there's your problem!
The vacuum hoses is plugged in. Car runs great now. Only issue I have is the no boost gauge.
Not sure which one you're referring to when you said not plugged in.
I followed GTSboys advice and unplugged all the vacuum lines that I showed in the picture and only left the blue one (from the balance tube) to the stock boost gauge sensor. Didn't get any feedback on the gauges when I was in boost on a drive.
Ok so I will be the first to admit that I made an ass of myself for assuming someone else knew what they were doing.
Issue is fixed. Guy never plugged the vacuum line to the balance tube nipple. It was in the general area (on the throttle body rod assembly, in his defense it does look like a nipple lol) unplugged everything in frustration and realized it was never plugged in.
Issue is resolved. GTR is good to go. Thanks for your help guys. Sincerely mean that.
  • Like 1
  • Haha 1
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
