Hey there everyone,
I've got my 4WD light on at the moment and have the code "5,6" on the attessa module with the led light. From what I can see that means "E-TS oil level switch and/or circuit".
Could this be a faulty fuse, switch or possibly the system needs to be bled (considering the gearbox, engine and transfer case were just out)? What is the most common cause for this problem? Thanks everyone!
On 4/10/21 at 8:10 PM, Aiden7 said:
Hey there everyone,
First thing i would check is the oil level in the boot, then I’d bleed the 4wd system
On 04/10/2021 at 6:40 PM, Aiden7 said:
Hey there everyone,
OK what's it doing on the 4wd ecu ? When you say 5, 6 what do you mean ? On 33 GTR code 56 as you mentioned is low fluid level, but is indicated by 5 fast flashes then 6 slow flashes. If you have 5 slow then 6 slow flashes that is codes 5 and 6 not 56, which is your front right and left abs speed sensors in fault.
If so this could be an indication that they are not connected in the engine bay.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
