Hey guys i recently swapped my r33 from rb20e to rb25de s2, now it runs n drives but i cant get my idle lower then 1500, ive looked for intake leaks by spraying start ya bastard to see if it picks up and i get nothing so i replaced the intake gasket set and rechecked for leaks and still nothing, ive cleaned the iacv nothin, ive wound out the idle screw, removed the iacv plug nothing, turned the cas to see if its that but no, but also  when removing the intake i got water in the engine so i blew it out then removed the plugs and wound it over to clear it out its fine now but smokes abit now any ideas on both my problems would be great cheers
https://www.sau.com.au/forums/topic/483532-high-idle-issues/
On 10/4/22 at 3:15 PM, BK said:
You mean in right ? Out raises the idle speed.
Haha yea man I only mentioned it so everyone knows what I’ve tried, its wound all the way in now still the lowest rpm is 1500
On 10/04/2022 at 2:05 PM, C.callander said:
Yea thats my thoughts but should have jumped in rpm squirting the start ya bastard around but it didn’t
You mean it should have dropped rpm, but maybe you just haven't found it yet. Keep trying everywhere like injectors, brake booster, etc. Good luck.
On 4/10/2022 at 12:00 AM, C.callander said:
So I’ve found no leaks but I’ve found the earth to my iacv isn’t working, is it an constant earth to the battery or does it get its earth from the ecu
IACV/AAC valve is normally closed. So without power it should be fully closed. Fix it but that's probably not your problem.
Only reason I think its iacv is cause of this
Constant 12V means that the other side (the earth side) is the switched side. If there is no earth there, then the switching device is not switching it on.
The IACV is not just a simple device though (ie, not just on-off). Look at the manual for what you can expect to see when it is working, and what you might see when it is not.
The hose you clamped is not just for the AAC valve, there's also an intake air regulator/cold start valve in there that affects your idle:
Verify that your cold start valve is actually getting power and closing after some time. To some extent this is just guessing because your intake is clearly not stock and it's unclear whether the routing of your vacuum lines is still the same as factory especially because your crankcase vent lines are gone. I also must emphasize that as a general rule once you set the AAC idle screw on an engine that is otherwise mechanically perfect (no leaks/etc) you should never ever touch it again. Your idle getting out of whack is never going to be fixed by touching a screw that has extremely limited control authority, and it is never a good idea to band-aid over some issue with air control by touching that idle screw even if it does work.
Edited by joshuaho96
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
