Changing the old coilovers in the Skyline for brand new ones.
Front driver was rusted on at the bottom where the 17mm nut is. I used a ball joint splitter on it which got the coilover out but it's left the inner metal ring with the rubber on it. I've used Wd40 Penetrant, shock treatment with a hammer, and heated it up with a heat gun but it won't budge.
Any suggestions?
Have a couple of pics attached for reference.
Cheers
Edited by BlackLine33
https://www.sau.com.au/forums/topic/483620-r33-gtst-coilover-removal/
get it nice and warm with a blow torch (no idea what a heat gun can do, but not enough), the get a pry bar behind it and shock it loose. If you need to get a grip on the bush a big pair of vice grips would help
On 5/7/2022 at 7:16 PM, BlackLine33 said:
What Dremel model would you use?
Doesn't matter. I have one of the original quite small ones. The small friction cutting discs that fly to pieces and take out your eye work, as do the thicker fibre reinforced ones. The thinner grinding wheels work. Steel cutting burrs work. Any of the larger Dremels that take bigger discs/burrs are also good. A 4" angle grinder will do the job, if used very discretely. A reciprocating cutter can also work. I just use the word Dremel to indicate anything that can cut/remove metal at a smaller scale.
looks like you haven't hit the thread underneath, so no issue there.
you should still try to get a pry bar behind it to shock it off, and heat will help. You only need to break the seal then it will come out reasonably easy
I'll try a blow torch and pry bar next. What do you mean by shock it off?
I mean, grab a pry bar or even just the biggest screwdriver you have that you don't care too much about, lever it between the bush and something solid, then give the end of the bar a firm push (perhaps even a whack with a hammer)
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
