My R33 was stolen this morning, please help...
Hi Friends,
At 445am this morning 27/08 my Silver R33 GTS-T was stolen out of my driveway.
It was hooked up to the back of a big ute / truck thing and pulled away....
My front door camera was very very dark but you can make out someone fiddling for ages at the front, then rolling it to the back of a big vehicle off camera, and then being pulled away.
REGO - WCB 666
Silver, r33 GTST.
photos attached.
Please let me know if anyone spots it...
(perp vehicle passing my house and doing a u-turn to wait just off camera - video attached)
It has an alarm / immobilizer but of course the battery was flat because I hadn't driven it in ages. I took it out of the garage to clean the garage and didn't put it back because i was investigating putting it into a wilsons storage etc. So i thought what was the point jumping it to move it if im just going to have to do it again soon to move it into storage.....
sigh.
please help all, many many thanks.
Thank you.
  • Sad 4
There isn't really much point in chasing them up. If they come across it by chance they'll contact you.
I hate to say this but there really isn't anything to look for anymore. You can almost guarantee that it's sitting in a garage somewhere being stripped down for parts. The parts will never be recovered, the shell will be chopped up and thrown in scrap steal recycling :(
I don't know why people keep saying parts. Surely the sum of the parts are greater than its whole these days given their renewed value? Or are these morons so stupid they just think "duh parts duhh"?
And for that to be true (which it is) you cannot hope to sell it in Australia for use in Australia. If it's not being cut up it will be going in a shipping container to the Middle East, or the USA, or somewhere in the EU, where there is money to pay for it.
Cars only get stolen for a few reasons generally, for example -
A. Joy ride. This starts with stealing the keys, steal the car, joy ride the car, burn the stolen car.
B. For use in another job. This starts with stealing the keys, steal the car, complete unrelated job, burn the stolen car.
C. For export out of Australia. Cars get put on containers to certain parts of the world. You can imagine the logistics behind this. The way your R33 was pinched wasn't exactly professional and R33gtst's aren't the typical car getting targeted by professionals.
D. The 'f**k I crashed my R33 and I'm not insured' person, now I need a car to rebirth or a mountain of parts to restore said crashed car.
So as no one broke into your house, took your keys then took your car, I'm going with option D as the most likely.
Except that the price of skylines have skyrocketed in Aus. But yeh, I getcha. I still want her back ofc :(
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
