Hey, I have a rb20 w/r33 turbo swapped r31, the car runs, and idles fine with no issues, however whenever its revved to above 4-5k+ rpm when you let off the throttle it goes down to 0 rpm and stops running, it doesnt sputter or make and unusual noises just falls and doesnt recover. If you blip the throttle to catch it when falling its fine and goes back to idling normally. Wondering if anyone can help me out here, I really don't know what I'd be looking for on this. After fiddling with the AAC valve it seemed to fix but when I tried it again a few hours later still was doing it. Perhaps the AAC adjustments didnt do anything and instead once its warm its fine (yet to test this).
Any help appreciated.
  • 2 years later...
On 25/09/2024 at 6:23 AM, EndZee said:
Broooo have exact same issue. Did you solved it? Please answer
You've given zero info about your setup.
Step 1: make sure all the standard equipment are working as they should. If they're not, go investigate why.
Step 2: Make sure all your wiring is done properly. Know which RB20 you have, most likely "silvertop" a.k.a R32/A31 anything after 1989.
Step 3: make sure your ECU is tuned properly. Standard will barely run in this situation.
Sorry for late answer but here’s my spec:
Series 1 1994 r33 gts25t AT converted to MT using r32 rb20det gearbox.
Custom self made clutch pedal
os giken twin plate clutch
two pins connected to let engine start
speedsensor from AT connected to wire harness but didn’t fit to gearbox So it’s somewhere inside in the car so I can add km to tachometer after I measure distance with gps. Don’t want to pay 150€ for sensor if I probably will change gearbox with adapter to bmw one. Car barely runs and winter is coming so no point right now
engine after rebuild
Stock automatic ecu and at tachometer
Aftermarket oil cooler with separate sensor so oem oil pressure is unplugged
koyo 53mil radiator
Mods which may cause the issue:
600x300x76 front mount intercooler
Cone air filter blitz
Removed recirculating valve
Slighty bigger maxspeedingrods turbo
adjustable manual boost controller (didn’t set it but last time I checked on aftermarket gauge it was 0.4bar, asaik oem is different unit 7(unit) don’t want to rev it too high bcs it made max 70km after rebuild
Fuel pressure regulator set to idk 30-32psi at iddle
dw300 fuel pump
stock injectors
check valve right in front of fuel rail
i thinking sth wrong with afr it getting too much fuel and too less air or it needs that recirc valve?
on warm engine it took 5-10 seconds to start it. After I put way bigger battery, battery terminals and new ecu coolant temp sensor problem is gone
my old turbo spill 150ml oil into intake so cleaned it.
I checked for error codes and it given me 55 - all good. I bought consult so will plug in soon to check if it give me better feedback. Also I will install oem recirc valve tomorrow. Small hose going to manifold but where should go 30mm pipe from this valve? I’m front of turbo inlet, after maf/ right after turbo outlet / or it doesn’t matter?
actaully can install it in these two spots (blue circles)
57 minutes ago, EndZee said:
here’s link to photos bcs can’t add it here
blue spots - I can install recirc valve hose there and in general everything air intake related so you can spot of anything wrong here
Stock ECU with no recirc valve is a bad, bad combination. Hot wire MAFs cannot deal with reversion, even if you don't vent to atmosphere it will shoot back out when the throttle snaps closed all the way out the compressor inlet and MAF before getting sucked back into the engine. It double-counts the air, the engine runs way too lean and stumbles if it doesn't die outright.
Thank you. Can you please check where should I add hose in intake pipes? From recirc valve back to intake? I upload photos on imgur.
 In front of turbo inlet, after maf/ right after turbo outlet / or it doesn’t matter?
https://imgur.com/a/wC4y8ro
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
