  • Replies 234
Nice pics dino.
Yeah to explain that last one... I was having heaps of trouble with my tryes by that stage... they had gone really off and it just stepped out on me... sorry motoconcepts... next time I'll get some better tyres and hopefully they will grip for a whole session!
Can't wait for the next day at oran park on the GP circuit... bit more scary drifting those corners though I would think.
My 60 Year old Mum was glad she came for a squirt (Except for turn 2 Drift), but she did say I would have no chance at getting her back on the track again. Bonks please post or send any/ all the pics you have.
Thanks
P.S. Mum thinks you are all, in her words " A bunch of really nice guys"
Originally posted by ultim8DTM5
When's the next one? The barina wants in on the action, so does my Uncle Rob with the black MY01
Oran Park on Sunday 16th of Feb 2003.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
