I'm trying to order the release bearing, the part number seems to be 30502-69F10 (?)
Nengun says it is no longer available.
https://www.nengun.com/oem/nissan/30502-69f10
1997 GTSTS2
Is there a replacement part # ?
Cheers
For what it's worth, Amayama lists some potential replacements:
https://www.amayama.com/en/part/nissan/3050269f10
I don't know whether this is right for you though.
What is your situation?
I have started doing research for a clutch refresh on my car and the release bearing comes with the Nismo kit that I'm looking at.
  • Like 1
4 hours ago, Torques said:
Hi,
The situation is that I need the standard OEM release bearing for the standard clutch ... :)
Even the genuine one is an NSK bearing - it's not like Nissan make their own bearings.
Hi,
Yes, thanks for the input.
I'm more than happy to buy from NSK or NTN or SKF.
It would help if I had the OEM dimensions but according to SKF I might have found something using
30502-69F10
https://vehicleaftermarket.skf.com/mt/en/products/VKC3737
Most people will be using the Koyo bearing RCT40SA3 from somewhere like CBC here in Australia.
There is a factory Nissan replacement of 30502-69F1A, but it's 100% a Koyo bearing anyway.
Hello,
Thanks for the input.
I also saw the 4075-1S listed as R33GTST  bearing
https://koyo.jtekt.co.jp/en/products/detail/?pno=RCT4075-1S
Here's the 40SA3
https://koyo.jtekt.co.jp/en/products/detail/?pno=RCT40SA3
Major difference seems to be 'd' which is 74.5mm vs 82.2mm
Too bad I don't have an old bearing / carrier  to check.
  • 3 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
