Hello I had pulled the head off the rb25de from an r32 to check if oil was getting to the head and my buddy told me that these heads tend to float valves around 400whp so I decided that since the head was off again to get upgraded valve springs.  I've read on another post that it would take rb20 valve springs but can anyone confirm?  I'm going to be going with the super tech valve spring kit with retainers.  They have a kit for rb20 and 25.
https://www.sau.com.au/forums/topic/484328-r32-rb25de-valve-spring-upgrade/
39 minutes ago, GTSBoy said:
On the Kelford and other spring website it says rb25(with NVCS)  and they specifically have springs for rb20/rb25de(nonVCT) I went with the super tech valve spring kit for rb20.  I believe the ones on supertech are for rb25de are for r33 rb25s with vct
Edited by Prof_Finesser
On 8/29/2007 at 12:07 AM, Cubes said:
Ahh I was under the impression you went with the R32 RB25DE head. :D
Yes the R33's run 2 different length springs; they are a tad more than the r32 springs from Performance springs in QLD.
The factory springs may very well do the job with the r33's. The problem witht he R32's is that the springs they use in the R32 Rb25DE head are the same as they are in the RB20DET head. While they are fine controlling a smaller valve with the rb20; once you shove more weight behind from the rb25's head them they struggle. :S
Let us know the seat pressure just for my own curiosity. If need be shim them up a touch to get around 50-55 pounds.
this is what I also found earlier in the day
14 hours ago, GTSBoy said:
Hmm. I guess this makes the thread good reference material for the possibly two or three people in the future who will try something similar with an R32 25 head.
yea I know most people don't really build these so.
There never was that many of them in the first place, and it was all such a long time ago. Like hen's teeth. Most people, including myself, apparently, barely even remember that the R32 RB25 was closer to the RB20 than the R33 engines.
This was my first skyline I used to have a e36 m3 and getting this engine I did have to do some research about a couple things but not too much.
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
