Hi I'm having trouble with my bov. Got it all recirculated but when I put the vacuum line on the bov I get no boost. The previous owner had blocked the bov and had the vacuum line running back to the other lines. Could it be the bov has a big leak? Sorry still new to turbo cars. It's a r33 with a rb25det. Cheers
https://www.sau.com.au/forums/topic/484466-no-boost/
Yes, this is probably the issue. a BOV is literally a big boost leak by design.
It needs a vacuum line to the top of the BOV from after the throttle. If you don't have the same pressure in that vacuum line as the intake, the BOV falls open.
https://www.sau.com.au/forums/topic/484466-no-boost/#findComment-7976051
This is how they'll previous owner had the vacuum line setup for no bov. I reconnected the line circled to bov but get no boost.
https://www.sau.com.au/forums/topic/484466-no-boost/#findComment-7976057
28 minutes ago, GTSBoy said:
That line that runs from the closer T piece and heads to or under the crossover pipe. Is it connected to the crossover pipe nipple there or is it connected to a steel pipe that goes further forward?
It goes to a steel pipe under the crossover pipe further to the canister. Could it possibly be that the person that did it had the boost gauge hooked up the those lines?
https://www.sau.com.au/forums/topic/484466-no-boost/#findComment-7976065
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
