Hey everyone,
I'm looking for some advice with a dilemma I'm having on choosing which direction I should go with upgrading my RB25DET's oil pump.
The current one is an N1 with a billet gear, and I wouldn't know whether the backing plate is factory or aftermarket as I bought the engine from the previous owner who had it built.
My first reason comes down to my own fear and uncertainty created from all of the horror stories I've heard about N1 pump failures although I know half of them are due to dodgy installation, and my second reason is that I feel that the capable power figure for my current fuel and turbo setup would be right at the edge of what the N1 can safely handle as moving forward I'd like to have the headroom to aim for bigger power safety with the piece of mind.
Originally I was considering going with a Nitto pump until realising that the whole engine would need to be disassembled as the crank snout would require machining to suit an upgraded crank collar to pair with the pump . Which obviously isn't a viable option as it's already a brand new built engine that had just only finished being run in for 1000km before I bought it.
However I've come across a examples of RB's running external wet sump oil pump setups instead which has sparked my interest in them, such as this kit from Ross Performance
https://golebysparts.au/products/nissan-rb-ross-lh-mounting-single-stage-external-oil-pump-kit-race-series-damper-306500-104?variant=15660827246701
as I've been thinking about if this alternative could be worth it rather than the expense and time that would be involved with the original idea?
I'd love to hear any opinions/suggestions yous may have to offer,
cheers.
https://www.sau.com.au/forums/topic/484484-oil-pump-upgrade-dilemma/
Just run oil pressure to your ECU and shut down the motor if you lose pressure. Most N1 pumps in the world don't fail, the biggest risk factor seems to be bouncing off the rev limiter like a foo.
Of course if you are thinking big big power (you didn't really give a figure above) then you should be changing to a different oil pump setup as the fundamental design from nissan was not great for quadrupling factory power....external wet pump is better a bit of a half pregnant option, dry sump is the way to keep a big $$ engine safe
  • Like 2
You would assume a crank collar would have been fitted during the build process.
  • Like 1
Sorry for the late responses.
I left that out by mistake Duncan, my bad mate. The power I want to make for now is between 600 - 650hp ish (it hasn't received a power tune post run in) and my ultimate goal I'd like to eventually achieve would be 750 - 800hp if safely possible, which is why I'd like some headroom with the pump.
I have looked into dry sump kits as well but honestly speaking that wouldn't be an option within my means, unless you could recommend a cost effective way to piece one together?
I also know an external wet sump system isn't a full measure compared to dry sump, but how would one stack up against other aftermarket internal oil pumps? Between the two which would you suggest, and what would be the pros and cons of each?
Thanks.
I'd like to, but I spoke to the original owner the other day to ask him and he wasn't sure at all but said he would ask the engine builder, which is making it less likely.
  • Sad 1
Thanks.
Regardless of what oiling system you use, the key is to setup limits and cuts based on oil pressure. I have tonnes of cuts and limits on mine. Duncan's advise is spot on. You dont need dry sump for 800hp. If you are really paranoid, then add Accusump or some sort of oil accumulator to the mix.
  • Like 2
I know some people have gone the external pump with a wet sumo route, but I use nitto internal pump (which seems to be very similar to the Tomei pump). A external pump requires a crank mandrel to drive it, mounting and an extra belt to throw or misalign, I don't see that is safer with a wet sump
  • Like 2
Thankyou both Predator1 and Duncan for advising me and my apologies again for yet another late response, I don't mean to make a habit of it.
I knew that it was probably a long shot but due to the high chances that an aftermarket crank collar wasn't fitted when the engine was built, I couldn't help hoping that a external wet sump system might be the workaround for the engagement issues that the stock collar has with conventional pumps, as well as a solution wouldn't require engine disassembly.
I'm still quite the long way off from my project running and driving as the engine has to go in out a fair amount of times for test fitting and fab work which could take a good while, but once I get closer to that stage when I'm more able too, I'll cop it on the chin and get a collar fitted and a Nitto pump like originally planned.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
