Hey guys I’m looking at running my rb 180sx on e85 I’ve got all the ethenol rated lines to run the fuel but I was wondering if the factory 180sx fuel tank can run e85. I’ve hear a bunch of different thing like steel tanks can’t hold e85 but I’ve also heard things like aluminium tanks can’t hold it either. I’ve contacted a company about one of there fuel tank dealing products and they said that almost all of the fuel tank dealers on the market don’t work .
any help would be greatly appreciated cheers
https://www.sau.com.au/forums/topic/484633-180sx-on-e85/
Everyone runs E85 in original steel tanks.
You can have extra corrosion issues because E85 can absorb a lot of water (compared to plain petrol) and have it sit on the bottom of the tank. In practice though, most of the stories where this has happened and caused problems involve really unusual circumstances.
Just do it.
  • Like 3
https://www.sau.com.au/forums/topic/484633-180sx-on-e85/#findComment-7978761
I've been running e85 in my 180sx for well over  8 years. Replaced filter sock after first 3 months then around 4 years later. Fuel filter gets replaced every 12ish months.
Never had an issue. When stored for 6months or more always had a full tank with a bottle of additive.
  • Like 1
https://www.sau.com.au/forums/topic/484633-180sx-on-e85/#findComment-7978763
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
