Hi.
As of now i dont what happened(update comming soon)...but i just dont WTF was happened.
Head and top of the engine was rebuild last year...it ran great. I ran like 5k with no problems and car ran good when you take to consideration that is kinda slow have 216k km and is old.
But it ran.
Yesterday i took it to a trip and when i was near home i started to smell like burned plastic...i thought it is from outside. But when i stopped at the lights the smoke starts pour from under the car(engine)
So i stopped the car and take a look. My hood do not want to open so i try to look everywhere i could. I stall the engine and after like 10-15 min smoke was gone.
I saw nothing burned nothing smell ...nothing. So maybe some plastic melt or something "plasticy" drop on exhaust. I started up the car and it went good...nothing. No smoke no smell and car ran great.
I was like 20 min from home so i ride.
But after like 10 min i started to smell the plastic again...and of course on the lights there was the smoke again.
Iam not going to push it but i need to stop elsewhere and. Car still runs normally so i ride like 2-3 min to park the car and call the "angels".
BUT then suddenly car make some wierd noise(i was low on gear and it sounded like the car was not happy on low gear and low rpm)...but then again the same noise and car just stalled.
I drifted to side of the road. Car (engine) was smoking.
I manage to finally open the hood.
Now what i found. There was nothing burned. Smoke came 100% from the engine. Car did not wanted to start (cranked 1 times...sounds bad) so i leave it.
The radiator was cold...(like how?) there was no leakage as far i could se. Oil was at the top and do not look bad(was changes like 800km ago).
The back of the car(more near the exhaust side) was covered with oil/fuel? Something oily. But smoke or any type of smoke was really came out of the engine only...no smoke from exhaust(i looked at mirror constatly)
I know "magic ball" but WTF should have happened? Car was at the mechanics like month ago and he checked all fluids and any "service" things and all was good...and car was good runned normally until this happened.
https://www.sau.com.au/forums/topic/484639-cooked-enginerb20de-neo/
@GTSBoy I "IF"...why? The gasket was brand new. Any reason for that? I do not race the car or otherwise abuse it. The whole "trip" the car has seen red(7k rpm) like 10 times max. I know that temperature gauge is not 100% accurate but it was at the center whole time(it should work...it goes down when the car is cold) so idk 😕
@Duncanidk i do not check at the time(my mechanic will) but i kinda dont think so...or at least not "much" cuz when the car stall on itsefl and i manage to open the hood the radiator was cold as no "hot" water was even there 😕 after like 10-15 min the radiator was starting to get warm/hot.
I have done brake swap from GTT so i checked everytime i ride for spillage underneath the car...and no drop. Even my mechanic looked last time(like 14 day ago) and car was bone dry ...no leakage or anything...
So i think something goes horrible wrong...again 😕 I know it is old car and things can go bad but i really dont know why this was happened.
Understood, but unfortunately a key reason for a cold radiator is that there is no coolant in it, it will just be at ambient air temp then....
It is way hard to guess without seeing the car, but coolant can look like smoke and no coolant feels like cold coolant
  • Thanks 1
4 hours ago, Kapr said:
Hi.
But it ran.
Most engine rebuilds are not that comprehensive purely for cost and time reasons. Also when it isn’t your engine you really don’t care that much if it’s messed up or not. Hence why everyone says rebuilds “let the Nissan magic out”.
The fact that your radiator is cold suggests you had a major cooling system failure. Within 5-10 minutes of driving it should’ve been too hot to touch with your bare hands. Coolant temp at the top of the radiator is going to be like 80C. Blocked thermostat or similar blockage in the system, water pump failure, etc can all cause these kinds of symptoms.
  • Thanks 1
@DuncanI think so too...but dont why suddenly i start to loose coolant...but i guess that it is how things go bad.
The smoke was only from the engine...no smoke from exhaust. And when i checked the oil it was fine(no milky just regular colored oil)
Yeah i will see this week what went wrong.
@GTSBoyYou think it could like "self destroy" after a year? The gasket was done like year ago and i drove the car couple of k km. But i dont know how these things "work" and if it can go bad like right away or just like this...
@joshuaho96I know but do not have a choice. Not many people here gonna work on that car/engine (as far as i know i am the only with this type of engine). Most of them(even that still no many) have GTT and have no time or they want like fortune just for a small things.
Yeah i start to think so too...i know i touch the radiator many times before to check and it was HOT to touch..no it was only little warm on left and in the middle where the cap is...completely cold.
The "block" thing should have been the problem..or the pump but it is/was new...done with the belts and everything around last year.
I will let you know but i think too that something happened with cooling system.
But thanks for the tips guys 🙂
Usually it happens again as the problem that caused it originally wasn't sorted properly, better off to put an import motor in than repair it.
The gauge won't show it's hot with no coolant because the temp sensor is dry, if you suspect it's losing coolant in the future try the heater on hot as they usually lose water out of the heater core early on so if doesn't blow hot it's losing water.
Happy new update(since last tuesday)
It was ONLY the broken hose from the heater core. Heater core was leaking so we took it out like month ago and just "connect" the hose until the new come out.
Being the 25 year old Japanese rubber...the hose do not like the new position and being "too" close to the exhaust(even with heat shield) and just broke.
So no HG no nothing.
My mechanic even told me(i did not know that) that Skylines have overheat protection when the engine starting to overheat they just cut the fuel...and that is what happened. Next day when the car was cold it started like new.
So at least something was not completely wrong 🙂
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
