As we all know petrol prices are phuckin ridiculous at the moment, especially if ur driving imports cars and the like. My question is which premium unleaded petrol is best to use here in PERTH, Caltex Vortex or Shell Premium Unleaded?
And don't say use BP Ultimate...! :D
ta :D
https://www.sau.com.au/forums/topic/48535-quick-petrol-question/
if ur running the stock ecu shell premium will do u fine, its 96 RON. its even better if u shop at coles as u get 4c off per litre :D
caltex vortex is 95 RON and has an injector cleaner in it. it make my car ping with stock ecu stay away from it.
Gull's premium unleaded is suppose to be 98 RON, but i haven't used it yet.
that said if you have an afterward ecu or major mods i would only use bp ultimate 98.
As you prolly know - BP Ultimate is only made in Kwinnana and distributed Australia wide (kinda sh1tza when it's cheaper in Sydney than Perth doesn't it). I suspect that it is also sold under another brand, but have never had this confirmed.
For this reason alone, it should be the freshest fuel providing you buy from a popular station.
Paul, that reminds me - make sure they drain my fuel and change the fuel filter before firing up the new donk- that crap's been sitting in my tank for 8 months now!
Gull gets the dregs of the other fuel companies, kind of the crud that's left over from all of the crude oils
Caltex Vortex is 97RON though, but yeah has cleaner in it
thanx for the replies guys, apparently and sadly my line is a *cough* n/a *cough* :Oops: but yea never use normal unleaded but, always use premiums at least, ok just checked their websites and shell is 96RON and vortex is 95. But the thing is i think i always gets more kms from using vortex, no noticable difference in terms of performance though. and yea i kinda mix the 2 together sometimes, i hope thats ok?
Hi Guys. There is another thread going in the General Automotive about different fuels at the moment. I just left a message on that to direct people to the thread below from back in May. There is a fair amount of discussion in it, but some quite informed views. The main thing to note for us in Perth is that every last drop of fuel that you buy in Perth originates in BP Kwinana. Shell, Caltex and everyone else buy the raw 95 ron Premium off BP and add their own soup to it to make it theirs. Shell claim their standard premium is 96 ron, but they are starting from a 95 ron basic fuel, bought from BP. So anything else that they gain in octane rating is achieved through additives.
BP Ultimate is the only thing to use!
Here's that thread:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=38750
Cheers.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
