Hey guys just wired in a 25 into my r31 the car runs and starts fine but am having trouble understanding how to wire up the vct/o2 my understanding is they are powered off the same wire, I’ve read elsewhere that one wire for the vct goes to ign 12v and the other to ecu pin113, hoping some can shed some light for me as there are only 2 conversion guides I can find but one is just a alteration of the other and isn’t any clearer to me, cheers
Edited by Liam2421
Spelling mistake
https://www.sau.com.au/forums/topic/485351-rb25-into-r31vct-wiring/
22 minutes ago, Liam2421 said:
I have a copy of the ecu pinout as per this guide https://wiki.r31skylineclub.com/index.php/Wiring_an_RB25DET_into_an_R31
You should have the wiring diagram handy and not just the ecu pinout. VCT on an R33 is one wire to 12VDC (Originally from fuse #17 but any 12VDC will do) and other wire to pin 113 on ecu. VCT solenoid is not polarity sensitive.
  • Like 1
Ok I’ll try get my hands on one but perhaps you could tell me if it goes off the same wire as o2 sensor Hopefully can kill 2 birds with one stone if I just tap ignition and the pin 113 into that, thankyou for your help
Yes, it's the same 12VDC circuit that feeds the O2 sensor, AAC valve, Boost control solenoid, etc.
  • Thanks 1
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
