As Dose said before, if u want to spend cash do it on more value for money stuff.
But if u have the cash this is cool, but it’s designed to sit on top of the RB25 lower shell
Edited by Watermouse
  • Like 1
12 minutes ago, R32.RB said:
90mm throttle body
big throttle bodies don't magically make more power.
You only need to go bigger if you have more boost pre throttle than post throttle when at WOT.
68 or 74mm DBW is more than sufficient for most people.
Would a 74mm be fine for a Neo 25, 98 fueled 300wkw or 68 would be more appropriate?
Well, tell me how I can make around the 500-600hp mark with a T3 top Mount turbo if my Aeroflow 6262 .84 T4 is too big as I was going to build it for 5-600 and flex fuel and stages like boost Lvl 1 - 15 psi boost lvl 2- 20 psi boost lvl 3 27-30 psi for example
I'm running a greddy style plenum with stock throttle body on my rb30 (rb25 series 2 head) stagea, it is making 400kw through that.
There are plenty of ways to spend money on the car, you don't need to change the intake you have for 600hp
  • Like 1
74mm would be good, however you will find you will need to gently ramp in the pedal vs. throttle so it feels smooth and linear (not like those silly carb V8s where you touch the throttle 1mm and the car wants to fry tyres).
This is how mine is dialled in with a 74mm DBW TB, I wanted 68mm but Plazmaman couldn't weld a 68mm flange onto the plenum.
You said you want 373kW to 447kW, you don't need a 62mm turbo to do that, that turbo can spin over 500kW+
  • Like 1
Okay I must of got my letters wrong instead of hp  I’d like to make 450-600kw i know it’s quite easy to make it on an RB I already got the turbo for free so it’s brand new the aeroflow 62 .84 T51r mod already done T4 flange can I change it to a t3
but please tell me how
Is there a reason why you want close to 600kW in a R32 GTS-t?
Have you thought about suspension work, subframe changes (from a newer car, offsetting it), diff choice, brakes, gearbox?
There's a high chance you're running a RB20DET gearbox which will not like close to 600kW being sent through it.
Also a 6262 won't get you close to 600kW.
5 minutes ago, Watermouse said:
@Dose Pipe Sutututu  thank you so much, understand what u mean and appreciate that info
I think way too many people get caught up in the whole bigger TB for more power, but that's only if it becomes a restriction.
In a FI environment, the TB size is not as sensitive, where as in a NA environment, you find with the throttle at 100% and if the plenum still registers a vacuum, then your TB is undersized and requires to be upgraded.
  • Like 1
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
