Hey guys just wondering if I can get some clarification on this refrigerant pressure sensor wiring. I bought a 3 pin pigtail to wire in a refrigerant pressure sensor and I just want to make sure I'm reading the schematic and connecting it properly. My ECU doesn't have anything in pin 57 so I put a pin in and ran it to the WHITE wire on the pigtail. Then pin 48 to the BLUE wire and connected the GREEN wire to ground. After doing this I went for a drive and my CEL came on. The car also had jumpy acceleration. Since pin 48 is also the power source for the throttle position sensor I'm wondering if I messed up or reversed the wiring somehow. Any help is appreciated, thanks!
Well, what you've done looks correct, but only if the sensor has the same pinout as the stock sensor. If it's not a stock or stock equivalent, then there's some chance that you've got two or more of those switched, which could be anything from non-damaging to let-some-smoke-out.
  • Like 1
24 minutes ago, GTSBoy said:
It's not the connector I'm concerned about - it's the sensor itself. The connector is agnostic - doesn't care what you're doing with it. The pins on the sensor need to match what the ECU thinks it's pins connect to.
Right, sorryー I'm an idiot, of course it's the sensor not the connector 😳 So I just did some digging and found out the part number I was given by someone at Nissan is actually the wrong part number....so obviously it doesn't work properly and I probably fried something in the process.
With that diagram you posted first, often the adjacent section of the workshop manual will confirm what the wires actually do as well. Of the 2 wires between the sensor and ECU I assume 1 is power supply, probably 5v and the other is signal to the ECU, but it isn't possible to tell which is which from the diagram.
Unfortunately if you have grounded the ECU 5v output by accident you might have damaged the ECU (or if you are lucky just popped a fuse).
Why does the ECU not have these wires, was it a non-AC car or a different ECU to factory?
  • Like 1
It's an engine swapped car that I knew about when I imported it. What I didn't know is that whoever swapped the engine didn't swap the harness....so it's an RB25 with an RB20 harnessー a complete shit-show to say the least. For the most part everything runs fine (until I tried to hook up this sensor 🤦‍♀️) I feel like the ECU is fried due to the incorrect part number I was given but I'm able to get another one from a friend so once I order the correct refrigerant pressure sensor it should be ok....
  • Like 1
And double double triple double check the pins on the sensor, making sure you understand the orientation of the connector view on the diagram and hopefully the pinout on the sensor itself is documented on its paperwork, for comparison and triple double quadruple double checking.
  • Thanks 1
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
