Hey everyone!
After having all kinds of other jdm cars in the past I finally got my hands on a skyline! Say hello to my 1990 GTST!
Ended up trading a Harley for it which I was trying to sell to fund a skyline, normally things don’t work out that easily lol.
 Lots of little odds and ends done to it which I’m still finding. Biggest thing that needed to be done was fix a massive fuel leak which was bad enough that the engine wasn’t starting. Ended up only being a pinched O-Ring and dirty injectors. Swapped a 2nd set in that came with the car and drove it into the garage
Next up will be cleaning up the underside (lots of old rubberized undercoating everywhere) giving it a good coat of POR15 and getting some of the smaller things taken care of
  • Like 1
https://www.sau.com.au/forums/topic/485653-new-from-canada/
19 hours ago, funkymonkey said:
Welcome to SAU. Looks great. I’ve got a soft spot for Do-Luck body kits on R32s, can’t wait to see it painted!
Thanks! It definitely looks a little better now. Hit it with some bumper paint for the time being, the entire car (minus the carbon fenders) will be getting either resprayed or wrapped at some point but that bumper just stood out too much lol
  • Like 2
https://www.sau.com.au/forums/topic/485653-new-from-canada/#findComment-7991441
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
