Just a thought: have you looked up the part number on https://nissan.epc-data.com to see if it is shared with any other model?
I know nothing about the ignition internals but if you can use one from a different car it might make the search a bit easier.
Yeah I have, but the pricing is a little bit too high, think it was like $750 AUD. It's just a sucky thing to find, I think at this point I'm just going to have to wait for someone who is wrecking one.
Oh, I wasn't expecting it to be available new. I was thinking to check whether it's shared across different Nissans. Amayama usually mentions if the part is used in other cars. Might be easier to find a wrecked Skyline, 350z or whatever if it is also used there.
Have you talked to Jack Phillips JDM to see if they have anything? https://jpjdm.com/shop/index.php
With them it's worth asking as they don't list everything they have.
There are two. One with "intelligent key" (proximity key) and one without.
https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/pm35/6844-vq35de/body/998
Doesn't look like a shared item outside of V35 Skylines which may be handy if looking for a wreck.
https://www.amayama.com/en/part/nissan/d8700cg027
https://www.amayama.com/en/part/nissan/d8700ac228
Edited by iamhe77
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
