Hello from Germany,
i build my RB25DET Series 2 -> Target 600hp
i have now ordered solid lifters from Tomei for the cylinder head and will replace the original hydraulic lifters. Which cams can you recommend ?
It is only a street car.... Maybe i order a Garrett GTW38 or something like that.
and what is with the VCT ? is it blocked with the solid lifters ?
Attention is a RB25DET with solid lifters!
Thank you for your help
Lifters (solid vs hydro) do not affect VCT.
For cams, just contact Kelford in New Zealand and tell them what you want to do with the engine and that it is a solid converted 25. They'll know what to give you.
FWIW... you can probably use any cam with either hydro or solids at that power level. By "any cam" I mean, there probably isn't a particular reason for the profile to be much different between the two.
FWIW I run Kelford 264/272 9.6mm and still retain VCT.
VCT is great, enables all that low end torque to help bring on the turbo earlier compared to a non VCT motor.
I also intend to go solid lifter at some point with my S1 RB25. I asked Kelford if I could use my S1 VCT 264/272 (246-A2) cams and they said no. They recommended that I use their 244 NEO cams.
when kelford answer me i will write it here. it depends on what kind of setup you want to ride.. i will take a Garrett GTW38 and 600hp for the street. and then they choose the cams...
4 hours ago, TomSky33 said:
Okay that sounds great!
How much hp do you drive and with which turbo ?
Made 439kW at the rear hubs at 1.8bar of boost tapering down to 1.7bar on E85. Has a (now ancient) Garrett GTX3576 Gen 2 with a 1.01 divided housing.
I just leave it on max boost all day lol.. car sees more track time than the street anyway.
My comment was aimed at the mention of possibly using hydraulic lifter based cams with solid lifters. I make a lot more then 600hp. It has nothing to do with power. Cam/Lobe profiles differ between hydraulic and solid lifters. Kelford stated their hydro lifter cams cannot be used with solid lifters.
Kelford will probably recommend their 244-A2 cams for your goals.
Cheers.
Edited by TurboTapin
Cheers.
Okay, I'm curious to see what they'll say. Do you also ride these cams ? or which ones do you ride ?
I'll have to think carefully about the turbo and manifold. The police in Germany are very strict
  • Like 1
Same as Australia, some police officers are strict and some are lenient and don't seem to mind the modifications, provided they are semi legal.
4 minutes ago, Kinkstaah said:
Germany is _very_ strict. Think along the lines of Mandatory full EPA every year.
Bolt up stock cat, run lazy timing on E85, should be fine yah? Lol.
I'm actually surprised he's considering running an aftermarket turbo, because the fact that it's not a stock turbo is deregister the car territory!
I would think Germany is the prime market for Hypergear highflows and ported stock manifolds, Nistune, Highflowed OEM injectors, super improved, ducted SMIC's and the like.
(or maybe it's not quite that bad)
It's not just an emissions test. Think of it like a full pits inspection with need to demonstrate engineering for any and all mods every time.
  • Sad 1
If the place was full of Skylines, then yeah. But there's not very many of them.
If you have a nice TÜV inspector you can get everything registered... well, almost anything. But it's quite expensive in Germany. As soon as something is wrong, the police tow your car away and it gets really expensive.
Almost all Skyline drive Top Mount... at least if you want to drive performance. The market for Japanese cars in Germany is not really big.
Kelford said 244-A's or 244-A2's.... I will probably take the 244-A2.
  • 1 year later...
I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters.
Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).
I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance.
I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
