"CAD" version 1.0
20250709_165217.thumb.jpg.6fd2ad6e9db7c6ac0b4c404e557080ee.jpg20250709_165226.thumb.jpg.6689ec9b2d797ab8cca4b77c7ca6ca56.jpg20250709_165648.thumb.jpg.9898cd2fbb7de1ec07eab40d86dbce08.jpg
It will have a 15mm lip around the top for 6 × 5 or 6mm nutserts and fixtures (two on each of the three straight edges), and some pinch weld on any exposed edges, it has three mounting points, one of the power steering reservoir bolts, and two on the rad support, my 120mm hole saw will make short work of hole for the silicone joiner, with ample room for some pinch weld
I've also got enough Carbuilders "peel and stick" heat shield to cover the outside of it at the coolant expansion tank and on the engine side, as pictured, and internally on the lid and where the fuse box is,
I've also got some thin, about 3mm, black 3M single sided sticky foam stuff that was left over after sealing some door drafts at home to help seal the lid
As for the shape, it "sort of" matches the shape of the fuse box, so shouldn't look to "out of place"
The lower area and hole for the intake will need pinch weld with a balloon on it to fully seal the hole and bottom of it, that will happen after it has been fabricated so I know exactly what size is required
Filter service has been trialed,  and so far it was a simple process
Just need to get some alloy, and then head into work to use the guillotine and break press in the workshop
Hopefully it should be sorted in a week or two
Guestimated outlay will be under a $50 for the stuff I don't have on hand (alloy, 6mm nutserts, the pinch weld, and wrinkle paint)
Disclaimer: That's what the "voices in my head" are telling me how the filter box should end up getting done......lets see if they know what they are talking about
  • Like 3
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002579
27 minutes ago, Duncan said:
you enjoying the snow, or did you get back to Sydney first?
Not alot here, just a random snow flake now and then, in saying this I didn't spend alot of time outside today, played in the garage for a bit, then spent most of the day pottering around inside
Did you get a bit?
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002597
no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list.
Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
  • Like 2
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002636
1.5mm alloy folded up, it will need a tweek, as the angled bend only got to around 45° as that was the max that the break press would get with the other bends, and I needed a fair bit more, but and the alloy is easy to bend too my will by hand once I trim the lower section out
I'll Dremel out and form the angle and mounting point on the lower section when time permits
As for the lid, I'm looking at going a "cap", instead of a flat lid to hide the fixtures a bit
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002765
2 hours ago, Kinkstaah said:
Is this where I say "Hey man my airbox cost me horsepower in my Naturally Aspirated Engine"?
(I know you need them for legality in NSW)
Nah, the OEM CAI pipe is still installed behind the bumper, it is about 5" x 3" oval at the engine side, tapering down to a 3" pipe behind the bumper where it gets all the ambient air it needs
Engine side of radiator support OEM intake pipe "oval hole" that is right in front of the filter
My OEM NC1 CAI pipe:
From NC2 onwards, below pic, they come slightly smaller at 2.75" diameter with corrugations and a resonance chamber to reduce intake noise, lucky for me my NC1 has the bigger noisy one, LOL
Basically, the "sealed" airbox will just get ambient air from a 3" pre filter intake tube that is the same size, 3" as the rest of the intake pipe post filter, and if a 3" intake isn't big enough to flow enough air for 150 killerwasps then there are other issues
The whole intake is basically the same length as OEM, but it is now about 30% bigger from the airbox back through to the new intake plenum than OEM, and the intake plenum is port matched to the head
And the intake is now about 30% bigger than my 2.5" exhaust, so the suck, squeeze, bang and blow black magic should be fine, well, to my uneducated understanding of fluid dynamics anyway
Talking the the guys at MX5 Mania, it may even make a few more killerwasps as the intake isn't sucking hot air, especially off idle or when in slow traffic when it would be sucking hot air
As for the difference in IAT, I haven't logged IAT yet, as I don't currently have a OBD2 reader, but I will have a play with my thermal lazer thingie next time I take the car out to sèe how hot stuff gets under the bonnet near the intake filter prior to installing the air box, my "assumption is it has to be much better after the air box is in and sealed up compared to what it is now
The aftermarket "performance" CAI elephant in the room:
Aftermarket CAI intakes typically have the air filter tucked up behind the bumper, with a 2.5" intake tube (the OEM intake pipe is actually about 30% bigger than the fancy pants "aftermarket" version.....WTF), and you need to remove the bumper to service the filter, which is a PITA
Like dis:
genuine-mazda-mazdaspeed-mx-5-miata-oem-cold-air-intake-2006-2009-41.thumb.jpeg.6e4c5c1ea9825788d257d5126b6ada3e.jpeg
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002769
I was mostly jesting. In my experience (and probably only my experience) the R34 GTT physical airbox space is actually too small to flow the amount of power it wanted. By sealing the box, I made it so it could only be fed by the ducts themselves.
So you can seal it up and get nice cold air which IS good, but at a certain crossover point:
More Hot Air > Less Cold Air
I don't think you're at this point. In my case merely ducting the hot air intake with a very focused set of ducts counteracts the fact it's in a V8 engine bay. More cold air obviously best. The solution looks great.
  • Like 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002771
If the gases flowing in those two tracts had the same properties, you could maybe use such broscience. But the exhaust has a different composition, different normal density, different actual density (because of different normal density, and mostly because of the massively higher temperature), and different viscosity (again because of much higher temperature). Consequently, all of the fluid dynamics parameters that matter, that you calculate from these inputs, such as the Reynolds number, friction factors (for wall friction) and so on, are all incomparable.
  • Like 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002774
Like I said, "black magic" LOL
In the end,  it is what it is, and hopefully, what this here knuckle head has done is an improvement and not a hindrance
Not that I actually notice any negatives now, or that I will get any seat of the pants benefits when all is said and done, but best practice says I shouldn't be pulling intake air from the hot engine bay
Famous last words: I cannot see it being any worse than what it is at the moment 🤔
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002775
1 hour ago, MBS206 said:
Just cut the bottom of the guard out. It's no longer got a big duct, to a sealed box, or a restriction. It has all the cold air from outside.
Also, that cai you showed looks terrible. Bends are NOT good for go gos!
No chop chop of anything mate, it is what it is, plus, I don't want any air that isn't either going through the cooling stack or intake getting into the engine compartment increasing under bonnet pressure
Yeah, the Mazda Speed aftermarket intake above is less than ideal for multiple reasons, the requirement to remove the bumper every time you need to service the filter, and also smaller in diameter than the NC1 OEM one
Weirdly, Mazda Speed is part of the Mazda motorsport division, "form over function" and $$$$$ for Mazda from unsuspecting punters I suspect
After some googling about them it seems they added no power, but do increase some induction noise
Meh
In other news, the electricians have been busy today at the house, and are back tomorrow finishing up all the security stuff and exterior lighting, they also added some lighting on the garage ceiling, which will come in handy when working in the garage when it's not freezing out there
My Birdies raised garden bed also arrived today as well, which I'll put together and place tomorrow, it's a big tall Bessie, 74cm high, 92cm wide and 214cm long, this will come in handy as I am starting to get "stockpiles" of good soils from doing landscaping, some of the clean rock, namely the river stone, will go into the bottom of the bed for drainage, as well as the old Apricot tree that was out the back,  and when it's full, I'll grab another one, I will be growing enough veggies to keep me both busy as well as supplementing the shopping list
I'm also awaiting another quote for a new Colourbond front fence, as the "1980 style cemented in rock edging" that was there and "fashionable at the time" looked arse, and my god, the amount of cement used to fix the rock was insane, it took 1.5 days for me to break out 12 meters of the stuff by hand, trim the bushes back to the fence line and dump it out the back of the joint to deal with at a later date,I will soon need a skip bin to tip it all
Unfortunately they did alot of the cemented in rock around the joint, which I hate, so a few pallets of retaining wall blocks for around the front and back where the cemented in rock is will be required to bring it up to a standard, and look, that I will be happy with
12 meters worth of rock and cement
Finished smashing the fence line and ready for a fence to be installed, yes, the lawns need some TLC and thickness, the previous owner trimmed the grass to the roots 😢, the TLC I can provide, and nature over time will do the rest
And there's probably about another 40 meters worth of this landscaping abomination left to do around the front and back gardens, I'm guessing maybe 3 or 4 tons worth, tip fees for this will be a killer
Meh, all in all I'm having fun and keeping busy, plus, it's good PT
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002778
You're retired Mark, on bin night, go for a walk, kind of like you're doing the beep test. Put one rock in the first neighbours, come back, get another rock, go to the second neighbours, repeat over many weeks. All rocks eventually gone...
  • Haha 3
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002779
That idea has crossed my mind, I do a 5km walk everyday, this does take me past some bushland......I think you may be onto something 😉
That, plus 1 rock on every bin night might do the trick, it may take a year, but it could save me a couple of grand
The only issue is the big 'Boonies", I have a few that weigh around 30-40kg, maybe they should be the first to go into the raised garden bed,  and then let the next owner deal with them....my daughter gets the joint when I kick the bucket, mums the word mate......LOL
Noice......
  • Haha 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002781
Take a couple of the big ones back to "work", leave them in the big bin.
Will make a good boom when the garbage truck emptys it out... :D
I've heard from another source about the boom when they had put I believe it was a 4cylinder engine in the big bins at Richmond base...
  • Haha 2
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002782
Version 1 aluminium airbox is.......not acceptable
No pics as I "didn't like the look.....alot"
Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner
I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe
This >
 Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though>
20241224_184725.jpg.24364a101f12196832aaaf0e91cb364a.thumb.jpg.3b01d6a367a9747f2aabde59175f896b.jpg
I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune
Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight
I am calling this a later problem though
  • Like 2
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002847
Funny story
Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power
It seems that I missed a hose clamp,  and the MAF and filter went WiFi
To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL
Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket
Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
  • Like 1
  • Haha 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002869
6 minutes ago, The Bogan said:
Funny story
Murphy strikes again!
Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it... :P
  • Like 1
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002871
I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
  • Like 2
https://www.sau.com.au/forums/topic/486007-nc-mx5/page/13/#findComment-8002889
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
