I wasnt comparing the weight of an SR to an FJ.Pick up an SR block and then an RB.......
What needs fabrication?My FJ makes 400bhp with stock throttle body,intake and exhaust manifolds and stock cylinder head.Im scared to think what power it would make with mods. :headspin:
Soi you really only need a bigger turbo, IC, injectors, exhaust and an ecu to get them going?
  • Replies 48
No I want the 3 Litres . RSX84 you mentioned wireing issues . Did you use the Nissan computer and if so was it difficult to splice into the HR30's electrical system ? I do have an SMC but would prefer a Nissan set up . Do you know where I could find a wireing diagram in English for the R32RB20DET .
Thanks heaps Adrian .
how you guys going with sump clearance? what about closing the bonnet?
thats the biggest problem with my S13, mounts have been lowered, sump hasn't been modified and sits on the crossmember, front of the sump is practically touching the sway bar. starter motor is very close to the steering column. all these little things are really starting to annoy me.
There are heaps of aftermarket bits for RB's which can be had reasonably cheaply whereas everything for the FJ has to be fabricated one off and costs a bomb
Damn dude u must be shopping at the wrong place!! I got a KKK26 meant to be good for 400-450ps at rear wheels, and a hks high mount manifold and 32mm external wastegate for $1000...JUst got a wolf 3d V4 pro for $700 as well last night, things arn't expensive for the FJ, you've just gotta look around a bit harder then RB/SR things
Nope , been fighting with my FJ for 6 years . Proven fact , cannot get 3 liter torque at low revs from 2 liters - not possible .
course you can...supercharge.....
why not build a supercharged and turbo charged FJ......guys have done it with 20V corolla's and nissan did it with the march gt super turbo ( i think that is what it was called) way back in the late eighties(i think, again)
I have recently finished building an RB30/25 DET hybrid, but am shelving it for now to investigate an L Series 3.1L Stroker for my PNV.
Just imagine a BOG STOCK HR30 Paul Newman Version, complete with L20A engine number, but 3029cc, T04R, 3 inch + system, about 20 psi, giving about 300HP at the treads.
what combination of top end bits did you use for the RB25/30 . are you interested in selling by any chance . Just a point of interest . the LD28 rods look identical to intercooled FJ turbo .
Cheers  A .
Answer to question about selling: No Chance, going away for Ron!
And top end bits:
RB25DE non VVT head, Trust inlet plenum, RB25DE throttle body, Gates T866 timing belt, HKS exhaust manifold with ext wastegate.......
Injectors, wastegate and turbo size etc, depends on how much HP you want,
BUT!!!! the biggest problem is not producing the HP, it's getting it to the ground without wheels spin. Your better to have less HP and no spin, than have heaps of HP and uncontrollable wheel spin everywhere.
Curses . I once also considered a monster L28 but was told that the head would impose unsolvable limitations . While I agree that at least it will bolt back in I would be concerned with chamber shape and turbo under inlet manifold . And man if I had the RB30DET it would not be sitting on the floor !
Do you have any pics of an RB in a R30 Skyline , particularly round the front cross member and gearbox mount . I think mine is going to have clearence problems around the front of the inlet manifold . Sadly the GTR manifold won't fit the 25DE/DET head and I probably can't afford an RB26 head . Even if I could I don't like the shim under bucket valve clearence adjustment - did someone say like FJ20 ?
Before I go what combination of loom computer and injectors did you have in mind for the RB30DET . A few go with RX7 injectors , RB20DET loom/sensors + PowerFC and Z32 MAF .
Cheers A .
Cheers  A .
I had a few concerns with the standard inlet of the RB25 fitting and that it came back across the engine, so the decision was made to buy the Trust inlet plenum, as it was only $200 dearer than a custom & it was tried and tested. It was also easier to do the plumming for the FMIC with the trust inlet
Series 4 RX7 550 injectors and all as you suggested, but maybe a re mapped stock ECU.
My sources tell me mounting the RB into an R30 is simple, goes on the stock 6 cyl cross member and use stock RB30 mounts.
My thoughts for the big L28 is to avoid emissions testing & further engineering in NSW, plus, as I have a limited edition as in PNV, I thought it best to keep it looking stockish and the 3.1 Stroker would be different, give the power to have some fun and look stealth to the ill informed.
The head limitations, I will probably get over when I flow the head. An N42 is planed, relieved a fraction to get the compression down to about 8.2:1 so that city drivability won't be to compromised off boost.
The heat issue will be adressed by HPC coating the turbine housings and manifold. Just having a big HP L series is a great temptation, although it ain't gunna be easy, the L28 uses a different sump, oil pick up etc system and the modification could be a real problem, fitting it into an R30 engine bay may become impossible.
Just sourcing the parts is not the end, hence a lot of thinking, and asking questions before this project will take off. The 3.1 stroker suffers from harmonics problems at 7200, has a tendancy to destroy the half moon keyway on the front of the crank shaft and likes throwing flywheels, so the crank has to be modified to remedy these problems.
there was a blue over silver mr30 sedan that sold for $21,000 mid last year that ran the rb30det. there was a web site set up with the start to finish process he went through..
It wasn't an rb30det,was just an RB30ET...It was from adelaide and i was fortunate enough to get a ride in it at one stage...It hauled ass :D:( I've got the link at home for it (its a mate of mine) i'll post it when i get home if i don't find it here at work whilst searching for it!!
Are there any differences between 6 and 4 cyl (FJ20) cross members ie where engine mounts go ?
Where did the inlet manifold come from , is it the top half only . Price ? pics ? It would have been intended for an RB20DET wouldn't it ?
Thanks , A .
The 6 cyl crossmember is swept back towards the rear by about 4 inches, give or take a foot.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
