So, I finally started digging at the bit of my roof that was cracking and bulging a bit. Well, it was just thick filler that was covering some pretty bad rust. I didn't find the edges, I was too bummed to keep going.
There are a few holes as you can see. There was just so much filler but looks like no attempt under the filler to prime or use rust converter, just slapped filler on exposed rust.
Anyway, I'm going to take the windshield out and find the edges. I'd love to fix this myself as I'm pretty sure it'll be expensive to get done properly. I was thinking I could just get a cut piece from another E39 and just weld it in place as it would be the right size and shape.
Thoughts?
  • Sad 3
https://www.sau.com.au/forums/topic/486367-rusty-roof-repair/
Hot tip, stop picking at shit. Live in bliss instead :P
From my recent experience in rust repairs, white it may seem to not go much further back, you'll still need to cut back a bit further.
From what I can see there, the outer skin, and the inner is rusted too. From what I can see you've got the inner one which is all structural, and window likely affixes too.
If tag Murray Calavera here, but my phone won't let me tag him, he'd probably be able to give the best advise.
I do know, welding roof panels is a right pain in the bollocks! Very heavy to heat distort the roof and warp it all.
  • Thanks 1
All good, I'll tag myself in lol.
1 hour ago, PranK said:
Thoughts?
What car are we looking at here? What is its value/sentimental value?
What type of repair do you want to do, 100% perfect back to stock or are you happy just to have the rust gone?
My initial thoughts are not very positive but I'll wait to see what your goals and thoughts are first before I start raining on anyone's parade.
  • Like 1
  • Thanks 1
Oh this is my 1998 E39 5 series. It's worth more to me than financial value. It's a project car for me to love and work on without fear of f**king up something that has lots of value or that I need to keep running.
Ok, thats a good starting point.
So before we start.... do you mind if the car say isn't a strong as it was before? My first thought is go excavating for rust. You'll be left with a gaping hole, that will be filled with fiberglass. You could make it look factory pretty easily but yeah, if you never crash it will never be an issue right?
Before we look at other options, how confident are you welding?
  • Thanks 1
I've never welded but I own a welder and I've always wanted to learn. In fact I had already looked at a 1 day welding course in Sydney.
I'd prefer some ugly metal fab than anything weak.
I'm challenging myself a lot with this car. For so many years I've just paid other people to do things and I've always been keen to learn and get better.
If your current chain of thought is, I'll go somewhere like pick and payless (or equivalent) and causally remove the bit of roof with your BYO grinder then casually weld that into your car... oof. It might sound easy but you will 100% end up with a warped roof. You say you'd prefer some ugly fab work, but I don't know if your prepared for how ugly this will be lol.
I've seen professional welders do similar but easier repairs and still end up with warped panels.
It is reasonable to assume that from your current skill level, you won't be able to do this cut and paste job while keeping flat panels.
Ok, but we are here to learn. This might be the go... jump on car sales, sort by price, buy the cheapest thing with rego and drive it home. This is your new practice vehicle. If you're thinking of doing the cut and paste job, try it on this car. Cut out the panel (hey it's a perfect fit) weld in the panel. See what you think of the results.
Next thing you could try, practice removing the entire roof in one piece by drilling out all the spot welds etc. Have a crack and welding the roof back on.
  • Like 1
  • Thanks 1
Ok so I will not defend my naivety. I regularly feel like things look easier than they are.
As much as I'd love to, buying another vehicle is out of the question. It was hard to get this car through the family process and we just don't have the room.
Hmm makes things tricky then.
I can't in good faith say, go forth my child and weld in whatever metal you remove in your quest for rust. I very strongly expect that adventure will end in sadness.
But you can't leave the car as it is, you literally have a hole in the roof. Also, I know you think the rust doesn't go much further, but the more I look at those photos, I really think the rust does in fact go much much further.
If you are 100% committed to being the only person working on the car.... stop where you are, hit it with rust converter, fiberglass, body filler, paint work, pretend you never discovered the rust in the first place?
Even if the body was repaired, painting the roof is a pain. Were you planning to use rattle cans to paint the roof?
Well the roof has a bunch of clear coat damage as well and I have done a little bit of spraying before so I was planning on doing the whole thing anyway.
I mean I could definitely clean it all up, rust converter it and cover it with filler. Same as the last guy. If that's the only sane option.
Welding thin sheet metal, is hard.
Welding thin sheet metal and keeping it in the shape you want, is REALLY hard.
Welding RUSTY thin sheet metal, and keeping it in the shape you want is nearly impossible.
A dodgy fix... Is cut the rusty crap out... Expanding foam, and putty/bog to rebuild that corner...
At least then you can reshape it to look half decent... Sprinkle some metal shavings into it too, then at least a magnet will stick to it.
Probably more bodge than Murray's bodge idea...
  • Like 1
With rattle cans?
There's a reason why the last person did that repair.
It's my advice for you as well, do as the last person did. Resist the temptation to go digging for rust, the hole you will be left with may wind up being so large that it's a nightmare to reform that corner of the roof.
  • Thanks 1
Yeah this can't be overstated, this job is crazy hard even for a professional.
  • Like 1
I have a decent compressor and spray gun. I haven't done anything this big but between it and the bonnet the paint currently is absolutely terrible and there's no chance I'd make it worse.
Ok so should I cut back the top flap to get to the end of the rust? The bottom bit looks bad but feels strong still, even with the holes.
Will filler seal the holes? Or should I put some silicon in them first?
Love your work guys, thanks. Can't tell you how bummed I am to have found this. Wish I'd never looked and I'd still be happy!
Filler will set solid and water tight.
If you need to, get in around the inside with silicon between the window and edge of the car, but only if that spot is leaking.
  • Thanks 1
Nice, saves me ranting about how painful it is painting a roof with rattle cans lol.
Personally, I wouldn't chase the rust back any further. What happens if your 30cm deep into your roof and still going?
This is why I was suggesting fiberglass, the holes are quite large but easy to patch with fibreglass. There will be a million youtube videos of people doing this shonky job you can check out for a visual.
Once the holes are patched with fibreglass, you can rebuild the corner with body filler (like the last guy did).
Indeed, its a shit go :(
  • Thanks 1
Haha 👍🏻
Yep ok, I'll just blast down between the panels with the converter.
Ok cool.
If I spray enough converter and seal it all up with glass and bog will it likely keep getting worse or will that do enough to stop it spreading?
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
