  • Replies 41
bwahahaha
i like the way you think snailperformance!! hehehe
See my problem is, i only wanted a black Skyline, i waited for months to find the right one... but now that i have it, it's a farkin pain in the rear...
So i liked the glitter, and thought it would disguise things a bit better, BUT after getting some quotes, it gonna cost almost as much as a colour change
So now i dont know what to do again... GRRR
and 2RISMO, have you seen mah car around babe? or just the pics on obsessive?
ain't nothing wrong with black cars... I'm gettin my car resprayed soon... I'll be using my stock colour as a base coat (which means I won't have an engine bay/door sill/boot lining of a different colour to the rest of the car etc) and then applying a red/yellow flake over it for that different hue in different lights. And if I have enough left over a lil bit of heat reactive paint on the bonnet :rofl:
mine is black and yes it does have that nasty habbit of getting dirty a little quicker than u would like, but i love it being black as looks noce n slik. If i were to go a lighter colour it would have to be that nice blue colour like the one i seen on a r34 gtr not too long ago, my jaw hit the ground :wassup:, so just need to get a little closer to 25 yrs old and save up enough for one just like it :aroused:
but in the meantime the gtst is all i need
hehehehe yeah i know Adrian... my little beep beep is still going babe!! hehehe
and thanks for all the info guys.... not sure what im gonna do again now
*sigh* thought i had it all worked out... GRRR!!
hehe
Damn stupid indecisivness!!! ROFL
ahh stuff it... ill just get a rb26dett conversion!! bweahahha
head on over the fast fours forum and do a search for " madhatter "
He is one of the best in the buisness and can do amazing jobs for alot less then you'd think.. Every bit of work I have seen of his has been A1!!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
