  • Replies 330
I reckon I'll be there, look on the bright side, cars glisten in the wet. Even a shitty paint job looks a million $$$. Might miss the BBQ if its raining though, done my time around a hotplate with a brollie up catching all the smoke, eating half raw snags in saturated Nike/Addidas/?????. But I'll pack for it anyway.
But the sun is gunna shine, the sky is gunna line [makes no sense, but sounds good] no evil thoughts here.
if we all polish/wax our cars nicely, we'll get that awesome beeding effect. i've had it for a while now, but it needs a clean.
they said it would rain today, and nothing happened until 5ish, and that wasn't even rain... stupid BOM.
Man, i hope Sunday is like today... Its SIC weather outside...
Just bought meself a pod for the weekend..... Someones gonna have to gimme someideas on where to out the freakin thing, it kinda sits funny :S looks good thou
won't be able to make the 12pm time....but i'll possibly ring Ewen and meet up later on if i can, and if it's not snowing!!!
my car won't be that great in a photoshoot anyway with a smashed headlight (STILL!!)...unless we take pics from the ass-end :D
Who is that idiot washing his car in the rain...................me me me me me
Just about ready, two new rear yokohama avs102's, mounting block for my EVC, and a clean up done, just a polish to go.......................now if only the sky would clear!!!!!!!!
Everyone pay attention to what Terminal has to say!!There's a positive in every negative!I've just finished going over my ride in time to hide it from the rain,but if worse comes to worse tomorrow,we can all get those cool water beading shots mentioned!Then you can at least tick that scenario off the list of photo oppertunities...
yeah, well i was just about to get my gal all gleaming and shiny, and then the heavens opened up....sigh....
just out of curiosity, what products do you guys/gals use on your liners? I use meguires, the paint cleaner is the bees knees, but havent used it on the new paint job, should be ok, but being a pearl, am a bit nervous! any thoughts/theories?
hopefully see ya all 2morrow!
i was bout to get mine done today too, damn rain!!!!
i'll give the interior a good schmicking up today, then hope for no rain tommoz morning.
i use meguires, does a great job and smells sooo nice!!!
see ya'll at midday!!!:@)
Hey THAT ME 2!!!!
was out in the rain washing the car, then its been in the garage all day, getting the beauty treatment. Got 4 new tyres today 2. And ive just finished the polish at 1:30am :D
IM righ to go... if it rains....then ill CRY!!!!!
See yas all very soon
