ok guys due to a discussion with a few of us in the members rides thread, it seems that an SAU-ACT photshoot will be a nice idea.
basically we just need as many of us as possible to get together so we can take some group photos of our rides (and us). :)
so we will need to find a good time so that lots of us can come (e.g. not at 11am on a tuesday lol) perhaps something like latish afternoon on a weekend as the sun will be highlighting the cars nicely and most of us will be able to make it.
so we will need to decide:
Time:
also does anyone have good equipment? or r u good at photography? if anyone is then we'd be happy to have you there to take pics. my sister-in-law is a graphic designer and has access to some really nice printing equipment so perhaps i can get some really nice, big, glossy prints made up after and give them out on a following meet?
anyway, feel free to put up your ideas and oppinions. lets make it a really nice one!!! :(
Andrew.
p.s. yes Gts_Duy: you can bring the seca lol!!!
https://www.sau.com.au/forums/topic/48765-photo-shoot-its-polishing-time/
  • Replies 330
For sure, loving the idea.
I've got a decent camera, not great, but okay. Has taken many a photo in 1600x1200 resolution, absolutely fine for online purposes, but not so good if you want these high-res glossies.
Anyway, great idea, we can hit up a BBQ, cruise, and photos in one day.
Is anyone particularly NOT free any weekend?
I'm screwed for almost every Saturday,so Sundays are naturally better...Having said that,I might be lucky enough to have the second weekend in September as my rostered weekend off.Maybe a day polishing/detailing on Sat',photo's and cruise on Sun'?Either way,I'm in if it's Sunday Setember 12th!
i reckon i'd be up for that. A chance to meet you all again and have alook at all the purrty cars. also i think the weekend of the 11th 12 sounds good as i've already got it off work and my b-day is the 13th :wassup: . party on the saturday night and a mad cruise on the sunday, wat a sick b-day this is gonna be. :)
yep, sounds sweet for me, i cant beleive the coincidence that your birthdays are on the 13th september....mine is on the 27th of april!!!!! how weird!!!!
lol Angus if u need a ride i should be able to take you, unless u live in woop woop, in that case i suggest u hitch-hike and take a ride from a stranger :headspin:
I don't have a Skyline but can I come along for the cruise???
i dont have a car and i'll be coming (i hope)
and andrew (veilside 33) umm yeah a lift would be nice, but ill ask my parents again and get back to you. Ohh and i live in chisholm.
ohh and whytry ill take that comment bout mine and your age as a compliment, as im glad im finally 15 :headspin:
