  • Replies 330
Thought it kinda sounded outlaw/pirate-ish, wasn't thinkin' of cryin' in my beer, more like the 'who was that masked man?'
But anyway, set a date [12th], location, and time, way things are going [no more R series] we'd probably be better off out at the dinosaur museum.................
ok how about this:
date: 12th sept
time: meet at midday for a chat and photos, go for a quick cruise to somewhere close by, more photos. then say head out to the cotter for a BBQ at maybe 1:30.
how bout we meet at the flags behind questacon for the 1st photos, and then pick another spot and take some there.
so hows about that lift andrew (V33), or am i to far out woop woop. I'm in chisholm
yeah mate, should be fine, i'll prolly end up sleeping over at a g/f's place in gordon anyway, so i can swing by ur place on my way. chisolm's close to gordon right?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
