  • Replies 156
This is for those that think that RB25s dont make a shit load of power and high revs on stock cams and heads.Check it out.
Hi Steve, on this dyno graph the AT is 21 degrees and the IT is 52 degrees.
On BMan's, the AT is 25 degrees and the IT is 31 degrees.
Help me out here, I am confused :confused:
PS; There are a couple of other interesting differences, but more on that later. I am more concerned with the temperature differences first off.
Melbourne is a very long way from perth.
ill be the guinea pig for this stupidly long-running debate
Im driving over there in as many months, and no doubt i'll be @ SST-Auto a bit checking it all out ;)
The final power figure was after a number of runs, and the intake temps get pretty warm, cause when doing a proper shootout reading the bonnet must be down.
Where was the IT temp probe?
:confused:
IT probe is infront of the air-stream going to the pod filter.
So the air coming out of the dyno cooling fan was at 52 degrees? That's a hot day for 11th June (winter), even in Perth. :confused:
:confused:
I'm not sure whether there breed you dumber over there or not, so I'll repeat myself slowly so you may understand.
The probe is inside the engine-bay, in-front of the airpod, with the bonnet down. After 7 or so power-runs the air gets pretty damn warm in there, the fan is directed at the intercooler.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
