  • Replies 156
This is for those that think that RB25s dont make a shit load of power and high revs on stock cams and heads.Check it out.
Hi Steve, on this dyno graph the AT is 21 degrees and the IT is 52 degrees.
On BMan's, the AT is 25 degrees and the IT is 31 degrees.
Help me out here, I am confused :confused:
PS; There are a couple of other interesting differences, but more on that later. I am more concerned with the temperature differences first off.
Melbourne is a very long way from perth.
ill be the guinea pig for this stupidly long-running debate
Im driving over there in as many months, and no doubt i'll be @ SST-Auto a bit checking it all out ;)
The final power figure was after a number of runs, and the intake temps get pretty warm, cause when doing a proper shootout reading the bonnet must be down.
Where was the IT temp probe?
:confused:
IT probe is infront of the air-stream going to the pod filter.
So the air coming out of the dyno cooling fan was at 52 degrees? That's a hot day for 11th June (winter), even in Perth. :confused:
:confused:
I'm not sure whether there breed you dumber over there or not, so I'll repeat myself slowly so you may understand.
The probe is inside the engine-bay, in-front of the airpod, with the bonnet down. After 7 or so power-runs the air gets pretty damn warm in there, the fan is directed at the intercooler.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
