14th VW Jamboree 18-19 sept Club Display
Guest darrinspencer
Who would be interested in a club display at the 14th VW Jamboree on the Sunday 19th September
Entry for a club display is free but the drivers need to pay the standard spectator entry cost $30 1 day and $50 2-day pass.
We are only able to have 5 cars total.
I am prepared to put my car (r33 gtst) forward need 4 more
Would be good to have a mixture of 31, 32, 33, 34 Gtst or GTR
Would also need to organise a club banner, flyers and some membership forms for on the day
www.jamboree.com.au
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
