just reading a post saying at compliance ill have to get side indicaters installed!!!
:throwup:
I dont want that, my car is pretty as it is!!
why would i have to do such a thing? could someone plz show me what they are gunna do to my "roger riceburner" (thats my car:))?
:cheers:
https://www.sau.com.au/forums/topic/49132-wtf-indicater/
It must be something recent because there are lots of R32's without it that must have been complianced before they changed the regulations. It sucks that you have to install the side indicators on the panel because there are plenty of factory cars that were sold in Australia without them, look at the 89 corolla or magna for example. What I don't get is that the front assembly light is alredy designed with a lump on the corner acting as the side idicator. It goes the same with the corolla and magna, the main front indicator assembly has a litlly lump in the corner of it, I guess that was a design trend back in 1989.
Ray
https://www.sau.com.au/forums/topic/49132-wtf-indicater/#findComment-983436
thats what i thought because it was so far around i didnt think it would need it.
anyone with pics would be cool though :cheers:
i cant recall ever seeing a r32 with side indicators, so im hoping and praying (and im not a religious man) that i dont need them ;)
https://www.sau.com.au/forums/topic/49132-wtf-indicater/#findComment-983461
two images of mine, without and with.
i had to have mine added for compliance over 2 years ago, the guy said that was the worst part about compliancing them because he had to cut into the panels :P
in the next few months ill be getting panels for it without the indicators.. nice and clean.
Shaun
https://www.sau.com.au/forums/topic/49132-wtf-indicater/#findComment-984214
the ones that dont have them are personal imports. maybe 15yr cars too, i dont know. but all others need them.
i think smaller are better. mine arent that bad but would prefer without. i think the key is that they line up with the GT badge.
mine are factory 32 GTR repeaters, and line up with the GT badge :(
https://www.sau.com.au/forums/topic/49132-wtf-indicater/#findComment-985784
anyone with pics would be cool though :(
i cant recall ever seeing a r32 with side indicators, so im hoping and praying (and im not a religious man) that i dont need them :(
Here's mine.. i rather like them... you'll be able to use side indicators off anything really...
https://www.sau.com.au/forums/topic/49132-wtf-indicater/#findComment-985794
Got my brother's 32 complianced a month ago, and was told side indicators weren't required anymore. Glad too because I didn't want them cutting into the side of the car.
Same deal with dash dimmer too, no longer a requirement.
https://www.sau.com.au/forums/topic/49132-wtf-indicater/#findComment-985973
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
