it all depends on what your having done? if your just installing speakers (i should slap you for not doing it yourself) but anywhere can do that. i dont really trust JB at all for installs, unles its just having a deck put in or something simple. but do you want show car work? or basic stuff?
BDL Fyshwick have done some really imspressive work, including the Jracing S15 and many other showcar installs.
also try Kustom car Creations, he's a member of syndicate and has apparently done some really nice work. O4O1 57O 98O, web site will be up soon apparently.
but if your just after basic stuff then pretty much anywhere can do it.
Straight up-go to Audiotech at Tuggeranong:I just got my R32 back from Tony and his crew-ABSO-FRICKIN'-LUTELY top notch job!!Can't recommend them highly enough!!Tell them I sent ya!!And if you're doubtful,check my car out on the photoshoot weekend!!
Thanks Guys,
I ended up going to BDL. Dealt with Adam mainly, very happy. Took his time to explain, didn't try to empty my wallet, and happily answered my dumbass questions. Other staff were good also.
Modest system, Focal splits in the front and 6x9 Pioneers in the back, sounds good to me though and the car was ready quicker than they suggested.
Regards
If you want to install 6x9's in the parcel shelf on an R33, make sure you have a day spare. it took me the best part of a day to get them in there, they need some hefty spacers. i've had 2 headunits stolen, so i know my way around that area of the skyline. There's a headunit install guide on this site somewhere, i think in the maintenance section. give it a shot, it worked for me, 3 times now. door speakers are easy to get at too, just have to unhook the interior door panels and they're right there. some people have put 6x9's in the side of the passenger walls, just above the armrest in the backseat, but that requires some cutting, and i wasn't confident i could do that nicely.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
