Hey All,
(I'm not complaining here - just hoping for answers)
Ok i have picked the car up from Mercury after having the Wolf installed and the car constantly stalls when slowing down - in fact it wont even idle. Mercury was trying for hours to fix this and are going to look at it again on Friday. It's like the IAC (is that it?) isnt kicking in - any thoughts? As for gains - on the standard computer the car made 157rwkw and with the wolf it has made 187rwkw.
  • Replies 65
How bout this, my car made 187.4rwkws before i stupidily put my car into Mercury motor sport for a front mount intercooler, when i got it bakc they said it made 190.8 rwkws but it had a shitty power curve and it was breaking down in higher rev range. So i take it back there and than they turn down the boost to what i had when the car came in, and now it makes 185.9 rwkws. Im so upset i usually go to APC and i thought id give somone else a go and now ive got problems after porblems. I just hope that Trent will be reasonable and hopfully give me a refund as i am not at all happy with the work he has done. Let me know if any of you guys have had problems Cos im in a really sticky situtaion. please help
Hey Drew
I was down there last night when you called Trent at about 7:30 and he was going to wait for you to bring your car down. I'm not complaining about how my wolf system is going as i knew there was always going to be dramas. But i remeber looking at your dyno sheet and it looked like a heart rythem - up and down all over the place. Mine was like that and the only way i could fix it was to replace my ecu - hence what i am doing. Given how your dyno sheet looked - i am surpirsed your car even made the power that it did. Having said that i am sure Trent will work something out.
I must say, Trent and co. are some of the nicest/most helpful guys i've had the pleasure of dealing with.
On Tuesday afternoon i rang them at around 4 o'clock and asked if it was possible to squeeze me in for an oil change that afternoon, so they stayed around until nearly 6 at night to get it done (i didn't get there until 5:30)
And today, even though they had alot of work on and were rather busy, they still managed to squeeze me in to get a piece of my exhaust fixed.
I'm very pleased with them, and their work, and they'll be getting my repeat business :)
Guys asking questions about performance / problems:
Please take your questions to the Forced Induction area... Not only will you keep this thread on topic, you'll get a wider audience and a better chance of getting your questions answered...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
