If you have an SAU email address that is not working at the moment, you need to change the pop3 server from www.skylinesaustralia.com to mail.skylinesaustralia.com .
In outlook (and outlook express) - click on tools -> accounts and its all pretty explanatory. For netscape users, start using outlook express. :)
If you have password errors after this, please let me know.
Christian
https://www.sau.com.au/forums/topic/49646-sau-email-address/
