Nearly 2 years ago Nathan was introduced to the fun of turbo cars, while not knowing they existed in the past year he traded in his Holden Ute for a silver R33 Skyline, it was fairly stock but he was lucky to pick it up with a HKS BOV, 3" cat back exhaust system, Gewalt evolution 3 Piece racing rims, GTR body kit and blitz sus pod filter.
First replacing the font & rear bar with a veilside products.
Going to macca's one night on Thursday and meet a guy called *stick* - owner of (Prospool Technologies) who introduced him to the world of modifying his skybeast. Starting off with a turbosmart boost controller boost was set to 10psi, only getting addicted to boost more, he then proceeded to Townsville drag strip which is 4hr's away from were we live (Cairns) Running a 14.1 @ 103mph as his best time of the night and first time down the strip he soon found out his clutch need replacing.
After the slow drive back to cairns modifications proceeded to installing a front mount intercooler, 3"dump pipe, Extreme 5 puck clutch and boost raised to 13psi.
Not long after that it was taken to the dyno and it made 184rwkw's
Back in cairns Nat set out to install a avc-r which was also the last night of his R33 Engine. While doing some testing at 12psi, the car was on full boost at 2,000 all the way to 7,000 after getting heat soaked, piston number 6 had
melted and all the ring lands went as well. Pulling up to the lights to only see a mountain of white smoke float past the windows, and hear the car blurping and, making the sounds of a dropped cylinder. It was soon to know that he need a rebuild.
Ordering parts from Stick and from Japan. The long wait paid off with the car finally running.
The car runs great and we havent had any problems. We are still running the engine in so we carnt get it tuned yet. But once the run in is complete we are expecting around 400+ hp at the wheels.
https://www.sau.com.au/forums/topic/49659-project-r33-finally-up-and-running/
The original modifications that were on the car were.
Blitz SUS Pod
3" turbo back exhaust
R34 GTT turbo
Turbo smart bleede valve set to 14psi
HKS SSQV BOV
Front Mount Intercooler
With these modifications we were able to achieve 184 rwkw's on pump fuel (96 octane)
The Full list of modifications are:
Arias forged pistons
Apexi Power FC
Apexi AVC-R
Bosch 044 Fuel Pump
Custom Stainless Steel Dumpipe
Custom stainless tuned length manifold
Custom Intercooler with stainless piping
GReddy Plenum Intake
Custom Garrett 700hp turbo
HKS Blow off Valve
Malpassi Fuel Pressure Regulator
Nismo 740cc Injectors
TurboSmart external waste gate 45mm
Tomei head gasket 8:1 compression
Veilside Body Kit
3 Piece Japanese Racing rims
3" Turbo Back exhaust
Guy's if your not going to post anything intelligent don't post anything at all.
This thread is not a advertisment its for general interest as BBQ stated.
5 simple steps on how not to blow up your "stock" RB25DET engine !
Step 1: Buy bigger fuel pump
Step 2: Have a front mount intercooler before boosting your car above standard boost pressure
Step 3: Keep boost to a minimum (9 - 12psi)
Step 4: Don't Flog your car for long periods of time on high boost & hot days.
Step 5: If you wish to further modify your car, purchase a tunable ecu, or do your engine internals.
Happy Modding :D
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
