what is the parking like arount eh place?  secure wise as well anyone know?
IMAX has its own secure parking right underneath.
Entry from Nicholson St or Rathdowne St.
i've parked my sky there for 2 years. not a problem so its very safe
Ok guys - I have been rung by IMAX and they have asked if we can all meet at 8:30 as they want to do all the tickets at once!
So we'll meet in the cafe/bar there at 8:30. Please dont be late or else you may be paying an extra $4.5!
Yeah Lygon sounds good if someone wants to recommend a place. I've never eaten there.
Well, NDSOC are also having a club night tomorrow night to go see NASCAR 3D at IMAX... they're meeting up for pizza and drinks beforehand at 227 Lygon Street, home of the Ferrari Club! then off to see the movie at 9pm..
For those interested meeting for dinner, we could meet at the same place tonight at say around 7:30pm.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
