52 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Might want to keep in mind there might not be any more 15y.o. imports after the end of the year, so surely a car like that would then be even more expensive? Just garage it, at least you know you're going to have something you like this christmas! :D
thats if that goes through...
good point tho.
  • Replies 94
doughboy has a good point.. either sell now for big profit.. and then with the savings ship something else over b4 the end of the year.. if that is shit, flog that off for profit again.. if not keep it.
Can't lose either way...
edit: actually get 2x cheapies, and keep the one that arrives in best condition :D
keep it Ni, U'll regret selling it...
By the way, I know somebody that has a tow truck that can cart it  around for ya......:D
lol serious? can i have his number??? :(
don't sell the car nark, just keep it for however long it takes. Just remember that you only got that car because of some favours that got called in (originally that car was goin to perth) and gettin another like it is pretty hard.
Also when you get that car you don't just get that car, you also inherit an ex tuning house car, AND the owner is keen on coming down and seeing it soon as well.
Look man half the guys on this forum have financial problems, me included. If you really like wht you have then you work around it. I've put off putting an RB25 in my car for yonks, but now I have the $$ to buy one so I am. Its taken me close to 6 months.
If you really need money that bad let me know how much and I might be able to loan you some.
that thing shitbox everyone say is nice just to make happy you.
sell it chip 10,000$ and buy big trailer with mota.
Your a fcktard...go away and learn how to spell....and your post doesnt make any sense......could it be MD?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
