I thought I'd start a new thread about this type of synthetic petrol, as its different from the other thread that talks about a diesel substitute. This fuel (called synjuice) is meant to be a substitute or blend for normal fuel (super or unleaded)
I have an issue of "modern MOTOR (may 1974)" – the height of the fuel crisis - which has a formula for making your own petrol. It consists of a blend of :
Toluene (65%)
Benzol (25%) – can be replaced with industrial alcohol but this wasn’t tested
Naptha (10%) - Heavy naptha, water-white)
Mix the ingredients (by volume) stir and poor in the tank through a strainer (you can get sediment from the naptha occasionally)
This mix is compatible with existing fuel and can be run on its own or in a blend.
This mix was tested on various cars of the day and "they all performed better and gave better economy .. than on either standard or premium octane petrol" - **I would be interested to know the octane rating of this mix, but I guess it must be in the mid nineties**
The article went on to say "we tested this petrol substitute in many vehicles without experiencing any trouble or damage to engine or any other vehicle components." but then went on to say "we accept no responsibility for any damage that might occur" (which makes sense to cover their own backs.
Has anyone ever come across this before, know anything else about it, or tried it to see if it works. :)
https://www.sau.com.au/forums/topic/50308-home-made-petrol-part-2/
i don't know about the price of toluene (naphtha is the active ingredient in zippo fuel tho :flamed: ..) ive never even heard of it before lol... but the point about the ecu's is definatly valid, im pretty sure that cars back around 74 with ecu's where rare as. but if it does supposedly have all the benefits that modern motor claim it to have; then it could be worth (or not) moding the ecu... but it is worth researching at the least. ill look into it and get back to ya's....
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
