Wanted to fine tune my ride a bit further before MAS coming up soon, throwing it on the dyno there for a bit of fun. Further from my mods already I put a s/s Hiflow 3" cat in and it made a huge difference. Was thinking about going with some octain booster and a few other little tricks......but decided against it, thought id just be proud of whatever i could get off pump fuel (synergy8000).
The tuning went far beyond what I had hope for!!!! initially after the last tune i had 224kW @ the rears.....so i was thinking, hopefully low 230's?? but low an behold.......my beast pumped out 248kW @ the rears!!!! i was STOKED to say the least :(
probably also worth mentioning that this set up is still a little on the rich side at top end (which I prefer to be safe) and still on STANDARD INJECTORS :headspin:
anyway, only few people really understood my excitement, so i thought I'd come on here an share my good news!! Fingers crossed that the dyno @ MAS reads a little higher than most (which I'm told they usually do) an I can get a hold of a 250kW+ dyno sheet :wassup:
theres a pic attatched of the dyno sheet. RED line= power BLUE=torque
the lower lines are from a few tunes ago, i think stock turbo @ full boost before i replaced it (round 18psi)
https://www.sau.com.au/forums/topic/50529-dyno-results-060904/
nice number.
but sorry to say that from that graph that doesn't look driveable at all.
at 100mk/h (I guess in 4th gear on an R33 is about what 3500rpm?) you have about 95-100rwkw
then at 120km/h you have about 220rwkw.. how the hell do you control that?
having said that, if you went from 224rwkw to 248rwkw from changing the cat, you gotta be happy with that.
that graph just looks REALLY peaky..
The tuning went far beyond what I had hope for!!!! initially after the last tune i had 224kW @ the rears.....so i was thinking, hopefully low 230's?? but low an behold.......my beast pumped out 248kW @ the rears!!!! i was STOKED to say the least :rofl:
What gear is that in? Third or Fourth?
220 in 4th gear? my r33 dyno run was done in 4th and only just got over 170 at about 7000rpm.
I could work it out exactly, but fourth gear in an R33 GTST is around 28 kph per thousand engine rpm. So 7,000 X 28 = 196 kph. :cheers:
TURBO: Hi-flow i got exchange through Daltons Automotive
PEAKY: havent really compared it to any other graphs, so not sure.....as far as drivability though, power delivery is very smooth, an yes, rapid, starts spooling up round the 3500-4000 rpm mark. Not much bottom end really, which I'm hoping to rectify somehow in future.
keep in mind that this is on a dyno....ie: no load, no resistance, no weight to push.....so its a bit more progressive on the road
GEAR: in 4th
an cuts off at 160kph.....not much point in graphing much further after peak is there? an the peak was @ 6100rpm
the small dip in the power curve can be fixed by some head/manifold/inlet flowing an polishing etc..
is there a certain way the graph should look? open to any comments or ideas...i'm all for making it even better :cheers:
well there should be load and resistance on the dyno. that's when they load it up once you're in 4th gear...
Of course it will be different to road type load but still, it just seems to deliver the most power from like 100 - 120km's where it jumps like 120rwkw..
it's just that I can't see how this could be put to the ground through rwd only..
then from 120km/h to 160km/h it increases by 20rwkw only.
is this normal?
it just doesn't seem like it would be a smooth power delivery at all.
almost like an ON/OFF switch
Thats mad abcent.. I'd be hell stoked too. By The Way.. what boost u running? A full list of your mods would be nice coz thats some sweet rear wheel Kw right there :D
I'm getting my car dyno tuned right now actually. They rang me up b4 and they said they have 215 rwkw on 12psi so far, pick up my car this arvo with full dyno sheets and hopefully a bit more power :(. Just need fuel cut defender before we jump up the boost... wondering how much boost the stock r33 gtst injectors can do? We're hoping around 16 - 17psi.
Thats mad abcent.. I'd be hell stoked too.  By The Way.. what boost u running?  A full list of your mods would be nice coz thats some sweet rear wheel Kw right there :P
I'm getting my car dyno tuned right now actually. They rang me up b4 and they said they have 215 rwkw on 12psi so far, pick up my car this arvo with full dyno sheets and hopefully a bit more power :D.  Just need fuel cut defender before we jump up the boost... wondering how much boost the stock r33 gtst injectors can do?  We're hoping around 16 - 17psi.
Thanks for the posative reply Geno8r
list of mods
Blitz s/s mesh pod
HKS fmic
hi-flow turbo (sourced exchange through Daltons Automotive) running 18psi
HKS dump, Blitz s/s 3" front pipe, s/s hi-flow 3" CAT, Kakimoto Racing 3" cat back
Stock engine, stock head, stock manifold, STOCK INJECTORS
Malpassi Adjustable fuel regulator (rising rate, black version)
Biggest (cant remember number) Bosch in tank fuel pump that'd fit
Microtech LT-12 ECU
GTST - have your dyno graph that I could compare with? just to see what you mean by "smooth power delivery"?
This is my everyday car, its smooth an streetable to me........I love it, cant wait to wind more out of it :P Its hardly a "wheel spin uncontrolably in the dry" car, It accelerates extremely fast and as smooth as i'd expect a turbo car running 18pound boost to be.
so I dunno, bout the same as it was with stock turbo & fuel system felt, just more power.
duty cycle is about 100% at peak power.
Thakns for the heads up, saving up as we speak for bigger injectors, but we all know the cost of R33 side fed injectors....., they HAD to be different to everything else...didnt they!
know of any cheap sets somewhere by any chance?
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
