HI THESE PARTS HAVE GOT TO GO!!!!!!!!!
SMS ME ON 0400200179 TO NEGOTIATE, EVERYTHING MUST GO!!!!!
Carbon Fibre 3D GT Wing $685 retails over $950
Nismo Stainless Carbon Fibre Muffler 3" Cat Back Exhaust System $600
Nismo Rear Suspension $100
Blitz "BIG" Boost Gauge $125
Blitz Exhaust Temp Gauge $140
Blitz Water Temp Gauge $140
4" Catalytic Convertor $130
Pierburg 400Hp+ External Fuel PumpsX2 $90 each
HKS (Green) Twin Pod Air Filters $120
Momo Corse Steering Wheel with Boss Kit $200
Pioneer P6550 In dash DVD Player (Touch Screen Like NEW) $2200 retails at $3599
Clarion 12" Subwoofer in Box $135
Small Amplifier to drive Sub $75
R33 GTR
Standard Sideskirts $200
Standard Mirrors $125
Standard Side Indicators $30
Standard Dash Instruments (34,803klms) $315
Standard Piping $135
Standard Fuel Rail $20
Standard Turbo's ( 1 missing rear wheel, no shaft play) MAKE OFFER!!!
Standard Oil Pump $115
Standard Oil Baffle $50
Standard Cam Gears $30
Standard Cam Cover $90
Standard Shifter $45
https://www.sau.com.au/forums/topic/50679-gotta-go-assorted-parts-gtr-others/
  • Replies 50
got a pic of the standard shifter?
will it fit and rb25det 5spd?
does it come with the circlip to hold it in the gearbox?
cheers
dave
not too sure as to whether it comes with circlip, dunno whether fits Rb25det or not
Are the nismo exhaust and suspension to suit R33 GTR???
hi both are for R33 GTR, exhaust system is like new very polished with carbon fibre exhaust tip with nismo stamped all around the tip with stainless chrome look, can have both together for $650. SMS 0400200179
Would these fuel pumps be suitable for a gtst. Also, would it be any hassles in installing them.
cheers
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
